Local Time 14:41 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bitmap sample
ztoti
Posted: 11:12am 28 Jun 2015
Hello,
According with MIcromite Manual Update, I've tried the command BITMAP 100,100,8 with no success, with message "Unknown command"
I'm running MMBasic 4.7b11 and all commands from this manual are working except bitmap command.
Any suggestions?
Thank you
Posted: 11:37am 28 Jun 2015
Works on b8. b11 is known to have issues don't use it
twofingers
Posted: 11:39am 28 Jun 2015
Hi ztoti,
BITMAP 100,100,8
should work!
Do you have the display initialized? (OPTION LCDPANEL ..., ...)
Regards Michael
The lone and ...
ztoti
Posted: 12:45pm 28 Jun 2015
Yes I did initialization, what I said it works on all command except bitmap.
Thank you Peter, I'll try it.
ztoti
Posted: 01:07pm 28 Jun 2015
It works on b8 !!!
Thank you
