Local Time 14:28 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite setpin at power up?
sagt3k
Posted: 07:39pm 11 Jun 2015
Hi Geoff
It is possible to think to create a function that save the settings and configs of the pins?
So that the next power up I've already the pins configured.
Posted: 07:55pm 11 Jun 2015
I'm curious - why would you need to?
As a first few lines of code, right at the top of your code, define your pins - job done. Time to configure the I/O pins would only be a few mS if that, depending on how many you are talking about here.
...I may well be missing something in what you are trying to do...
sagt3k
Posted: 08:31pm 11 Jun 2015
HI Grogster
Thanks, I know... I can set all pins with a few of instructions at top of my code.
But, when I mount my Pic in my application, where there are others devices, pmos, transistors, circuit for battery charger and so on, I think that ms is a huge time.
This is my opinion...
In truth, I have not measured how time micromite take to cfg all pins, but I think that a internal procedure wrote in C/assembler is always faster that Basic.
Posted: 09:00pm 11 Jun 2015
If your peripherals are so sensitive I believe that the best solution would be to use pullups or pulldowns on them. Then they will be in the correct state as power is applied.
Also, the problem with this is that there are hundreds of special features like this that could be added... where do you stop?
BTW the startup delay is about 250mS although I have not measured it accurately.
sagt3k
Posted: 09:09pm 11 Jun 2015
Ok Geoff.
I will try to set-up my circuit as you have suggested.
srnet
Posted: 06:56am 12 Jun 2015
Agree with Geoff on this one.
You should design your circuit so that it starts in a safe state, even if the Micro fails to start for some reason.
The MM pins will be as inputs at reset\powerup so if they need to be at a particular logic state to be safe, then pull up\down resistors as appropriate are essential.Edited by srnet 2015-06-13
$50SAT is Silent but probably still working.
For information on LoRa visit http://www.loratracker.uk/
