Local Time 14:28 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Port Function
viscomjim
Posted: 08:28am 10 Jun 2015
Working on a project where I need to read 4 I/O lines at one time and write 4 I/O lines at one time. So for the write I see I can use the port command something like this...
port(2,4) = &HF
But for the function to read a 4 bit port does one do this...
A = port(2,4)
or
A = &H(port(2,4))
assigning the 4 bits of the port to a variable?
Thanks!!!!!
Chris Roper
Posted: 08:51am 10 Jun 2015
  viscomjim said   But for the function to read a 4 bit port does one do this...
A = port(2,4)
or
A = &H(port(2,4))
The first option, if you then want it displayed:
PRINT HEX$(A)
or
PRINT BIN$(A, 4)
To separate the bits you could use:
bit0 = A AND 1
bit1 = (A >> 1) AND 1
bit2 = (A >> 2) AND 1
bit3 = (A >> 3) AND 1
Chris
Edited by Chris Roper 2015-06-11
http://caroper.blogspot.com/
viscomjim
Posted: 10:49am 10 Jun 2015
Thanks Chris, I will give this a whirl.
Chris Roper
Posted: 11:47am 10 Jun 2015
If you run this code you can watch the BIT's as you play with the input signals:
[code]
SetPin 2,din
SetPin 3,din
SetPin 4,din
SetPin 5,din
Print Chr$(27)+"[2;2H"; ' locate Cursor row 2 col 2
a = Port(2,4)
Print Bin$(a,4);
Pause 100 ' prevent flashing on cursor relocate
Loop
[/code]
