Local Time 14:28 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Logic Function Library
Chris Roper
Posted: 01:45am 01 Jun 2015
It is cold and wet here in the "fairest Cape" and my solder Station is outside :(
So I have suspended work on the devMite for a bit and turned my attention to MMBasic.
I needed some Bitwise Logic Functions and thought others may find them useful too.
They Complement the PORT command and PORT() Function and are also useful if driving Port Expanders etc.
For more advanced Logic I have also implemented a Bitwise Stack
' LIBRARY - Logic Functions
' C.A.Roper - 2015/06/01
' Version 1.0
' _____________________________________________________________________________
' Bitwise Logic Functions
' OnesComp%( Value% )
' Returns the BitWise NOT Function of Value% Equivalent to '~' operator in C
' BitGet( Value%, BitNumber )
' Returns the State ( 1 or 0 ) of BitNumber of Value%
' BitSet( Value%, BitNumber )
' Forces BitNumber of Value% to 1
' Returns the new Value%
' BitClr( Value%, BitNumber )
' Forces BitNumber of Value% to 0
' BitTgl( Value%, BitNumber )
' Toggles the State of BitNumber of Value%
' BitSet( Value%, BitNumber, BitState )
' Forces BitNumber of Value% to the State of BitState
' Where State is the Boolean Value of BitState,
' 0 or null = FALSE
' any other value = TRUE
' Bitwise Stack Functions
' A "Stack Overflow Error"
' Generated if > 64 Stack Entry's Result
' A "Stack Underflow Error"
' Generated if More Values are pulled than Entries Made
' BitPush( BitState )
' Pushes State into the Bottom of the Stack
' 0 or null = FALSE
' Increments Stack Pointer
' Updates the Stack
' Returns the New Stack
' BitPull()
' Pulls The State from the Bottom of the Stack
' Decrements the Stack Pointer
' Updates the Stack
' Returns the State Pulled
' BitSwap()
' Reverses the Order of the last two Entries in the Stack
' Stack Pointer is not effected
' Updates the Stack
' BitDup()
' Duplicates the Bottom Stack Entry
' Increments the Stack Pointer
' Updates the Stack
' Returns the new stack
FUNCTION OnesComp%(in%):OnesComp% = in% XOR &HFFFFFFFF:END FUNCTION
FUNCTION BitGet(in%, Bit):BitGet = (in% >> Bit) AND 1:END FUNCTION
FUNCTION BitSet(in%, Bit):BitSet = in% OR (1 << Bit):END FUNCTION
FUNCTION BitClr(in%, Bit):BitClr = in% AND OnesComp%(1 << Bit):END FUNCTION
FUNCTION BitPut(in%, Bit, Val):BitPut = BitClr(in%, Bit) OR ((NOT NOT Val) << Bit):END FUNCTION
FUNCTION BitTgl(in%, Bit):BitTgl = in% XOR (1 << Bit):END FUNCTION
DIM BITSTACK% = 0
DIM BITPTR = 0
FUNCTION BitPush(Val)
BitPush = (BITSTACK% << 1) OR NOT NOT Val
BitStack% = BitPush
BITPTR = BITPTR + 1
IF BITPTR > 64 THEN ERROR ("Stack Overflow")
END FUNCTION
FUNCTION BitPull()
BitPull = BitGet(BITSTACK%, 0)
BITSTACK% = (BITSTACK% >> 1)
BITPTR = BITPTR - 1
IF BITPTR < 0 THEN ERROR ("Stack Underflow")
END FUNCTION
FUNCTION BitSwap()
Bit0 = BitPull()
Bit1 = BitPull()
BitSwap = BitPush(Bit0)
BitSwap = BitPush(Bit1)
END FUNCTION
FUNCTION BitDup()
BitDup = BitPush(BitGet(BITSTACK%,0))
END FUNCTION
The Comment block is far larger than the actual Library so it included at the top to allow easy cropping in the editor before use.
Chris
EDIT: Note to Self
Build an Extractor and Move Solder Station indoors for winter :)
Edited by Chris Roper 2015-06-02
http://caroper.blogspot.com/
panky
Posted: 01:44pm 01 Jun 2015
Hi Chris,
Very interesting and clever way of implementing a bit stack using a single 64 bit integer. I kept looking for the array before the penny dropped
panky
viscomjim
Posted: 09:11pm 01 Jun 2015
Nice work Chris! Keep it going!
paceman
Posted: 12:22am 02 Jun 2015
Hi Chris,
You should submit these to Peter Carnegie (G8JCM) for the Micromite library - see the 'Sticky' post at the top of the Forum Topic list.
Greg
Chris Roper
Posted: 08:55pm 02 Jun 2015
  paceman said   Hi Chris,
Greg
Thanks Greg, I did think of submitting them but decided to hold off till I had used them in a couple of applications, in case I needed to add or change any functions. Whilst the logic is sound I may change a few functions into subs for better optimisation and ease of use. Several should be viewed as Commands rather than Functions.
At this stage though they appear stable in use, and I have made use of them in another library I am working on.
The more I use MMBasic the more I learn, so the chances are good that both library's will improve with my own skill.
ChrisEdited by Chris Roper 2015-06-04
