Local Time 14:27 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ili9341: magenta is the new grey
Posted: 07:41am 29 May 2015
I've been playing trying to plot some anti-aliased lines to make a better meter display when I came across the following issue (probably applies to the other displays but I haven't had chance to test them):
The display on the ili9341 has a 16 bit colour code - RGB565. This means that there are 5-bits defining the red level (32 different values), 6-bits for green (64 different values) and 5-bits for blue.
Geoff's code in 4.7b8 packs a 24-bit number into the RGB format by dividing red by 8, green by 4 and blue by 8 and then positioning the bits correctly in a 16-bit integer.
You would assume therefore that rgb(250,250,250) would give a light grey colour. Unfortunately it doesn't - try running the code below (the display must be in landscape mode). The workround is to add 1 increment to the green intensity.
option explicit
option default none
cls rgb(white)
dim integer i
for i=0 to 255 step 1
line i,0,i,239,4,rgb(i,i,i)
next i
line 256,0,256,239,,0
print "This is strange!"
pause 4000
line i,0,i,239,4,rgb(i,min(i+4,255),i)
next i
print "This is better"
end
function min(a as integer, b as integer) as integer
if a<b then
min=a
else
min=b
endif
end function
Edited by matherp 2015-05-30
viscomjim
Posted: 11:06am 29 May 2015
Do you think this applies to the ST7735 also?
Posted: 12:40am 30 May 2015
I have been checking the code and there may be a bug which is causing this. I will investigate further.
Yes, this bug would also affect the ST7735.
