Local Time 21:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 3D printed Circuit Boards
MM_Wombat
Posted: 10:42pm 26 May 2015
Saw this 3D printer that can print prototype circuit boards, or small run, that has a solder paste option with 550W reflow..
Could be useful..
http://voltera.io/
AussieWombat
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
Posted: 11:12pm 26 May 2015
WOW!
That thing is something I am going to keep a close eye on. Even if it is quite expensive, it would still be worth it due to the number of boards I churn out these days....
EDIT: $2,199 pre-order. I've seen much worse prices for CNC machines etc.Edited by Grogster 2015-05-28
Posted: 11:13pm 26 May 2015
Yes, it looks neat.
Only two issues... it is no good with thru hole components AND its price is $2,200. Gulp
Posted: 11:15pm 26 May 2015
Surely we here at the forums can put a MicroMite to work as a 3D PCB printer controller for twenty bucks?
CarlRanson
Posted: 11:27pm 26 May 2015
I saw one a few months back that had a bunch of interchangeable tool blocks in the top. would 3d print, mill, solder paste, and a few others I can't remember.
looked great but the build area was too small.
Posted: 12:00am 27 May 2015
0.8mm pin to pin pitch. That rules out almost all smd chips.
The pictures on the website on the left is from the machine drawing traces and pads.
The two on the right is a pcb from a manufacturer with soldermask and silkscreen, which both the machine is not doing.
It can also not use reflow with the printed traces as the inks will not stand up to the heat.
It sets the wrong expectations. Marketing crap. Always hiding the so important details.
The isolation patches to allow dual layers is nifty.
If only the minimum pin to pin pitch was 0.5mm and reflow was possible.
Maybe the next version.
Edited by TZAdvantage 2015-05-28
Posted: 12:12pm 28 May 2015
Hi All,
I see it as a step in `the right' direction.
BUT!!!
It is way too dear at $2200 (I assume US) that would make it well over $3200AUS by the time the Gov adds GST and you wont see it for about a year.
It is pretty limited in this current form..
I will wait until a better and cheaper model appears..
