Local Time 14:41 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite and RasPi
dasyar
Posted: 01:50am 23 May 2015
I have, on a breadboard, a MM 28 pin setup, which I have hooked up to a Raspberry Pi via the GPIO /dev/ttyAMA0. I am using minicom, on the Raspberry Pi, to access the MM, which so far is working as expected.
The question I have, to expand the Raspberry Pi functionality, by using the MM, can I, maybe using Python or C, or whatever, get direct access and control of the devices/sensors that could be attached to the MM, in real time?
Since I have an LED attached to pin 16, what would a program look like to maybe turn on/off the LED, from a program on the Raspberry Pi, as an experiment?
I am also aware of MMedit, which is only available for Windows, but that seems to go through a procedure of actually programming the MM chip. So, it is almost looking like what I would like to do, not possible, just want to confirm.
Posted: 02:08am 23 May 2015
the simplest approach is to write an mmbasic program that responds to simple text commands sent from the RPi. for example, you might use the following codes:
"2+" : set pin 2 high
"2-" : set pin 2 low
then from your python program just write the strings "2+" or "2-" to the serial port to turn an LED attached to pin 2 of the micromite on or off.
you could develop quite a complicated language for communicating between the two devices. but start with something simple.
rob :-)
CircuitGizmos
Posted: 09:01am 23 May 2015
How about just sending an immediate mode command? Just a string out the pi comm port for the MM to execute immediately? No program running on the MM.
Tim036
Posted: 12:06pm 23 May 2015
As an aside to this thread, I've found from an RPi to MictoMite, this works fine:-
picocom /dev/ttyUSB0 -b 38400 -l (lower case L)
(well worth installing picocom first *LOL*)
Tim
dasyar
Posted: 12:22am 24 May 2015
Since I am very new with this, how is that done, maybe an example.
Posted: 03:09am 24 May 2015
  Quote  Since I am very new with this, how is that done, maybe an example.
dasyar, you do need to get stuck into the manual, it is very readable and all the information is in there.
However - to get you going - all Basic commands can be sent from the console as well as appearing in programs. So to turn on and off an LED you need to go:
SETPIN 16,DOUT
pin(16)=1
pin(16)=0
The first command configures pin 16 as an output. The second sets the pin to a high level. The third sets it low.
You could also do things like:
SETPIN 2,AIN
print pin(2)
The first command sets the pin as an analogue input
The second prints the value of the voltage on the input
All this is in the manual
dasyar
Posted: 09:08am 24 May 2015
What threw me was "immediate mode command", yes I have been reading the manual, and aware of some the commands. I thought "immediate mode command" was something that you could issue from, lets say a com1 or com2 interaction.
I do not remember reading this in the manual, but can MM do threads or tasking? A task could be something like a temperature reading every 10 seconds and the reading gets placed into global variable where a main program or other tasks could read it. Of course the main program or task is running almost independently of each other.
Posted: 11:21am 24 May 2015
@dasyar,
Not really threads or tasking, but to achieve something like you mention you can use the SETTICK command which effectively is an interrupt that is called at specified intervals; so within the interrupt routine you can do something like read a temperature, and in turn update a global variable for use by the main program.
The manual explains the SETTICK command in detail
WW
dasyar
Posted: 02:38am 25 May 2015
I wanted to do a test run of something that would access the MM Console mode from a program. The program below uses freeBasic and is set up to do a simulated script routine. And to my surprise, it worked as expected.
All this is in hopes that when somebody comes up with a MicroMite HAT PCB for the Raspberry Pi , I will have some general knowledge as to how too work with it, at least I will know what my options are.
This seems to be feasible, you have the MM do its thing, while you can use all the Linux resources to support the MicroMite. At least this looks like a sound idea to me.
'MMledScript.bas
' Using freeBasic for the Raspberry Pi.
' Pseudo script program to be run with MicroMite Console hook up.
Open Com "/dev/ttyAMA0:38400,n,8,1,cs0,ds0,cd0,rs" As #1
IF Err <> 0 then
Print "Error opening port..."
goto finis
End if
Print #1, "NEW" ' Send with CR
sleep 3000,0 ' Sleep for three seconds
print #1, "SETPIN 15, DOUT" ' Send with CR
sleep 100,0 ' Pause for setup
print #1, "PIN(15) = 1" ' Turn on LED on pin 15, send with CR
print #1, "PIN(15) = 0" ' Turn off LED on pin 15, send with CR
finis:
print "Closing Port!"
'close the port(s)
Close
Posted: 03:15am 25 May 2015
Agghh, all that power just to turn on/off a LED.
When you get further into it you could have a program running on the Micromite that will take your commands and do all the flashing/whatever for you.
viscomjim
Posted: 03:24am 25 May 2015
maybe you could implement the I2C example in the manual to get an idea of using the uMite as a "port expander" type thing so you can see how the uMite could be running things and you are just throwing commands at it. Just a thought....
dasyar
Posted: 03:43am 25 May 2015
I already did an experiment where you use the Micromite as a stand-alone set up. I had a program that did some IO with an XBee attached to COM2, so from my desktop attached XBee, I could turn on/off an LED, on the MM breadboard setup, as a test.
It was suggested in an earlier post about doing some kind of control program on the MM to work with a login on COM1 or COM2. Just experimenting with some different ideas.
I do not make PCB boards, I stay away from doing any kits that require any soldering. Just a hobby to keep me interested in my retirement years.
