Local Time 21:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CPU SLEEP question
Posted: 02:48am 08 May 2015
I am not currently in front of any MicroMite to try the following so I am therefore hoping that someone out there is with one so that they may answer a query I have that is 'bugging' me.
The CPU SLEEP command has two different usage 'scenarios'. When used by itself, the MM will go to sleep and only wake up on a change on the 'WAKE' pin.
If it is used in the form CPU SLEEP xx then the MM will sleep for xx seconds and then wake up.
My question is this: If I put the CPU to sleep for xx seconds, then can it also be woken by a change on the WAKE pin OR will it only wake after xx seconds??
Many thanks from anyone that can provide any confirmation regarding this query . . . .
WW
Posted: 02:59am 08 May 2015
I use the WAKE pin, and the original method was that you could wake it up by a change in state on the WAKE pin.
In the latest firmware, you can still do that, but, as you already know, you can also set it to go to sleep for X number of seconds.
To the best of my knowledge, if you sleep the MM for, say, five seconds, you cannot wake it up before that five second period - it is more of a coma then a sleep, if you get the time wrong!
I have elected to use the old method, and external caps as discussed in a previous thread, as accuracy was not an issue for me - close enough was near enough. Naturally, that will not suit some other members...
Posted: 05:13am 08 May 2015
Hi Phil,
The easy way was to try it..
I did that and found that if you set a sleep TIME you cannot wake by use of the wake pin
Posted: 05:52am 08 May 2015
Thanks guys - not the answer I wanted to hear though
WW
Posted: 02:15pm 08 May 2015
The reason why the wake pin does not wake the MM when in timeout mode (and this is silly) is that I could not think of a good syntax for specifying BOTH the timeout AND the wake pin together
Does anyone have a good idea?
Posted: 02:18pm 08 May 2015
one method: use a negative time value to indicate that the wakeup pin should also be active during the sleep period.
ie:
CPU SLEEP -1000
to sleep for 1000mS with wakeup pin also monitored
rob :-)Edited by robert.rozee 2015-05-10
Posted: 02:34pm 08 May 2015
Rob comes up with the logic once again.
That seems like a really nice way to do it.
Simple and elegant.
You could then use CPU SLEEP 1 for a normal un-interruptible sleep, and CPU SLEEP -1 for an interruptible sleep of the same period.
Gets my vote.
Posted: 02:50pm 08 May 2015
Hi Geoff, All,
or simply,
CPU SLEEP, 1000, WAKE
or
CPU SLEEP, 1000, W
with ,W (inferring Wake Pin) optional
BobD
Posted: 03:39pm 08 May 2015
I like Mick's syntax with a mod. A zero timeout defines no timeout.
wake pin only
CPU SLEEP,0,W
or timeout only
CPU SLEEP,1000
or combination
CPU SLEEP,1000,W
Posted: 03:46pm 08 May 2015
Thanks for the responses.
I tend to favour Rob's suggestion. Therefore quoting BobD's examples:
wake pin only
CPU SLEEP,0,W would simply be: CPU SLEEP (i.e. as it currently is)
or timeout only
CPU SLEEP,1000 would simply be: CPU SLEEP 1000 (i.e. as it currently is)
or combination
CPU SLEEP,1000,W would simply be: CPU SLEEP -1000 (as Robs suggestion)
I prefer to minimise lots of commas when they are not needed. I think it may also make Geoff's task easier (remembering a similar topic before where a command became 'messy' with lots of unnecessary commas)
Guess there is plenty for Geoff to consider and hence decide the most appropriate way forward.
Thanks again . . .
Posted: 01:47pm 09 May 2015
Gday WW, All,
Firstly commas are used in many MMBasic commands and to move away from using commas is changing `tack' so to speak.
I do not think adding a ,W makes it messy looking in any way.
and
Secondly, I dont see -1000 as really telling the story of what it does like ,W does..
Also if you are using a variable say Sleep_Time you then have to manipulate the variable to include the minus where-as ,W doesnt need Sleep_Time to be changed.
In either case just having the command in whatever form Geoff decides to use would make it a step better than it is already.
Posted: 03:43pm 09 May 2015
  bigmik said  Secondly, I dont see -1000 as really telling the story of what it does like ,W does..
Excellent point. I withdraw my vote for Rob's idea(with no disrespect to Rob, naturally) and put it with Mick's.
Posted: 04:14pm 09 May 2015
i'm not quite sure how CPU SLEEP -T is too difficult to do. there is a long history of using 'invalid' numbers as a flag, in particular where a negative return value from a function indicates an error. but the nicest thing about using a negative parameter is that it requires minimal (if any) changes to the instruction parser within MMbasic. the sleep function, internally, just needs to act upon the negative input.
speaking of negative numbers... might i take the opportunity to push for the inclusion of MM.INTPIN in the next release of micromite basic? where the value returned is the number of the pin that generated an interrupt, and the sign is the polarity of the pin (a positive going or a negative going transition).
rob :-)
Posted: 09:03pm 09 May 2015
  robert.rozee said  ... might i take the opportunity to push for the inclusion of MM.INTPIN in the next release of micromite basic? where the value returned is the number of the pin that generated an interrupt, and the sign is the polarity of the pin (a positive going or a negative going transition).
YES PLEASE
Posted: 03:54am 10 May 2015
I like the ,W[AKE] idea. It is simple and will not break existing code.
But, why would we need MM.INTPIN? You can specify an interrupt specific to the pin, so you know what the pin is and by using the function PIN() you can find out if it was hi to lo or vice versa. Why clutter the language with something that is not needed?
Geoff (who is always trying to keep the language simple).
Posted: 04:08am 10 May 2015
I think it is so you can find out which pin caused an interrupt if you don't know which one it was - if you have several interrupted pins, for example, it would probably be handy to know which one was the LAST one to cause an interrupt.
I might not be understanding things right - it is 2AM.
it enables a single interrupt handler to service a number of pins that may be used for similar functions (for instance, sensing switch inputs) leading to much more compact and clear code. also, reading the pin directly within the handler - i surmise - is not totally reliable, as a short pulse on a pin could be gone by the time control has been transferred to the handler. the value of MM.INTPIN would be latched prior to the handler being called, and only cleared when the handler exits.
rob :-)
Posted: 06:49am 10 May 2015
@Geoff,
I would use a MM.INTPIN value to determine which actual pin caused an interrupt when using very short 'pulse' interrupts. As Rob highlights, if the interrupt pin has already changed state before the Int Service Routine processes things then it is impossible to find out which pin actually caused the interrupt.
If there is another way to do this then there is no need for a MM>INTPIN but I don't think there is.
WW
Posted: 08:03am 10 May 2015
@ Geoff,
I now see why you said your reason originally for not waking after an elapsed time OR the wake pin when the CPU SLEEP command was issued.
So if you want to wake the MM on the Wake Pin only; do you use:
1> CPU SLEEP (as it currently is)
2> CPU SLEEP,W (to include the 'W' as you say you like)
3> CPU SLEEP,0,W (as suggested by BobD)
4> CPU SLEEP,,W (no timeout required so leave parameter out - but still need the double comma)
5> anything else?
And if you want to wake the MM after a pre-determined time only; do you use:
6> CPU SLEEP 1000 (as it currently is)
7> CPU SLEEP,,1000 (logical if going with option 2 above - need the double comma if the W is the first parameter))
8> CPU SLEEP,1000 (logical if going with option 3 or 4 above)
9> anything else?
Finally, if you want to do timed Wake AND monitor the Wake Pin (as I ideally require); do you use:
10> CPU SLEEP,1000,W (logical if going with option 3, 4, or 8 above)
11> CPU SLEEP,W,1000 (logical if going with option 2 or 7 above)
Is a comma needed? What about brackets to 'contain' the parameters?
Can I propose:
1> Wake pin only: CPU SLEEP
2> Timed only: CPU SLEEP(1000)
3> Both: CPU SLEEP(1000,W)
I know this may spark a debate (hopefully!!) but open to 'comments'. Please note I don't know the level of 'impact' on the firmwares code so will need Geoff's response to say which is easy and/or least impact.
Personally I still think CPU SLEEP -1000 is the easiest and most logical - no commas or brackets but understand the usefulness of a 'W' in the command somewhere.
CPU SNOOZE . . . . .
Posted: 01:17pm 10 May 2015
MMBasic treats CPU SLEEP as a single command, so a comma is not needed after the SLEEP keyword.
I think that the cleanest syntax is:
CPU SLEEP
CPU SLEEP 1000
CPU SLEEP 1000, WAKE
The latter would wake up after 1000mS or on a change on the WAKE pin (whichever occurred first).
