Local Time 20:55 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Re-flashing the MX470
paceman
Posted: 03:37am 16 Apr 2015
I just did something a bit dumb but others might do the same thing so I thought I'd mention it and save some potential head-scratching.
I'm using a little dual 3.3 + 5v power supply for the 5v to the MX470 Skinnymite. I was attempting to flash Peter Mather's updated Beta 15 but was getting a "protected" error message back from the PiCkit3. I hadn't had any problem when I first flashed it with Beta 14. I finally realised I had connected the 3.3v from the dual supply to Vcc (pin 2) of the PiCkit3 instead of from the 3.3v 'Out' pin on the Skinnymite. I just assumed that's what I'd done when I first programmed the Beta 14 in, but I must have been more awake!
In my defence I've been doing all my 170 fiddling (28 pin) on a breadboard and I use the 3.3 and the 5v from the dual supply there - and for the PiCkit when I re-program. I can see why it happened but still, not clever - don't get caught like me!
Greg
Posted: 02:11pm 16 Apr 2015
There is always something there to throw you with this stuff!
Well done on tracking it down, and I admire you honesty.
