Local Time 16:08 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Celebrating 50 Years of BASIC
cdeagle
Posted: 03:25am 15 Feb 2015
Last year marked 50 years since the creation of the BASIC programming language at Dartmouth College. Interesting facts about BASIC can be found at the following link at Dartmouth;
http://www.dartmouth.edu/basicfifty/news.html
To show my appreciation for BASIC, I have made available the companion QuickBASIC programs for my privately published journal Celestial Computing at the following Dropbox location;
https://www.dropbox.com/sh/7i3ztymphqliqx3/AAAm-LO_40B7pR2kg gz8CzIka?dl=0
This site also includes PDF versions of the journal.
I am currently "porting" some of these programs and support functions to MMBasic. Here's a typical example.
' test_atan3.bas
' test atan3 function
' angular argument in degrees
theta = 195.457
a = sin(rad(theta))
b = cos(rad(theta))
c = deg(atan3(a, b))
print
print "atan3 computed angle ", c, " degrees"
print
end
function atan3(a, b)
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' c = angle ( 0 =< c <= 2 * pi : radians )
pidiv2 = pi / 2.0
if (abs(a) < 1.0e-6) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-6) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
Posted: 04:17am 15 Feb 2015
Interesting stuff.
For anyone who wants to read it, this is the working link:
https://www.dropbox.com/sh/7i3ztymphqliqx3/AAAm-LO_40B7pR2kg gz8CzIka?dl=0#
Oldbitcollector
Posted: 08:02am 15 Feb 2015
Most excellent! Thank you for sharing!
I'm going to repost your link to my forums .
My Propeller/Micromite mini-computer project.
Posted: 11:00am 15 Feb 2015
A interesting set of programs and very good explanations of how they work.
A great addition to the collection.
cdeagle
Posted: 01:17am 25 Feb 2015
I have been able to recompile many of the Celestial Computing programs using the QB64 compiler (www.qb64.net).
I have placed these Windows 7 executables in a subdirectory named qb64_exe and the "tweaked" source code in a subdirectory named qb64_src, both at the link given above.
I have tested most of the new executables but some may still have "bugs".
