Local Time 15:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite II 4.6 Dim,Local & Const
ajkw
Posted: 09:06pm 30 Jan 2015
RE MicroMite II 4.6
In a Sub a variable DIM'd is global and LOCAL is local but a CONST is not global.
Is it correct that a Const is not global when created in a Sub?
Anthony.
Posted: 10:29pm 30 Jan 2015
  ajkw said   Is it correct that a Const is not global when created in a Sub?
Yes, that is correct.
I just looked at the manual and that point is not covered, an omission I will fix.
ajkw
Posted: 11:18pm 30 Jan 2015
Thanks Geoff,
If I may however...
CONST & LCONST??
Actually after writing the example below I can see than this could break existing code so perhaps CONST and GLOBALCONST but that seems messy too. I don't know, it just seemed odd you can't set a global constant in a Sub but you can a Dim.. I'll leave it to you. /EndSelfDebate
Eg.
Dim x
initdevice 'sub to init a device
do
x = pin(DevicePin)
print x
loop
Sub initdevice 'this may actually be more complex than this example
LConst Somethingelse = 22
Const DevicePin = 1
Setpin DevicePin,dout,oc
End Sub
versus
Dim x
Const DevicePin = 1
do
x = pin(DevicePin)
print x
loop
End Sub
Posted: 12:37am 31 Jan 2015
I am of the opinion that defining something in a sub or function that becomes global should be totally impossible. :)
It is something that can only create bugs and will be extremely hard to find once programs get bigger.
If you want a global variable or constant, define it globally (somewhere on the top of the program).
ajkw
Posted: 02:18am 31 Jan 2015
For mine if you have a Sub that has a task of initialising a device and setting up your program for the use of it then it makes some sense to define any variables or constants in it instead of defining them somewhere else in your program separated from the Sub.
Posted: 03:27am 31 Jan 2015
If it makes sense to make some variabes global, then why not define them at a global level so it is clear.
Anyhting defined in a sub should be local.
This will allow you to reuse variable names in different sub and reuse subs in other programs and not have higher risk of breaking things when revisiting the code later and modify it by adding/removing/modifying variables from a sub.
You would end up with subs that are depended on eachother and the sequence they are loaded/run.
Ultimately it is up to the individual especially when code is not shared or reused.
I am biased by having to do a lot of software auditing. Just an opinion. :)
ajkw
Posted: 04:35pm 31 Jan 2015
I could go on but yes at the end of the day we can all do what we like with our own code :)
I simply found it inconsistent that in a Sub you can create (Dim) a global variable while not create a global Const.
Geoff has said he will fix the manual so that the behaviour is clear which is fine.
Edited by ajkw 2015-02-02
Posted: 06:27pm 31 Jan 2015
There is always GOTO (time to duck)
OPTION DEFAULT none
OPTION EXPLICIT
GOTO setup
main:
PRINT gl_test1
END
setup:
CONST gl_test1 = 25
GOTO main
ajkw
Posted: 08:45pm 31 Jan 2015
Jim, I love it, others will hate it but that' their problem
I am however not sure I will use it as I have essentially done away with GOTO and GOSUB but it shows there is always another way.
Cheers,
Anthony.Edited by ajkw 2015-02-02
