Local Time 12:36 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uMite 170 DOUT
ajkw
Posted: 11:18pm 25 Jan 2015
In regards SETPIN.
I am migrating to a uMite 170 (from a 150) and have seen the Oout command is depreciated in 4.6. As l need to read and write to a particular I/O pin l have found that DOUT,OC seems to make a replacement command including no longer needing a external pull up resistor.
Does the OC option enable a pull up resistor or is something else going on? (The manual only talks about internal resistors for DIN)
Anthony.
ajkw
Posted: 12:24am 26 Jan 2015
Not meaning to make this a blog but I found the answer in the manual. Page 30. SETPIN PIN,DOUT,OC does use an internal pullup.
Cheers.
atmega8
Posted: 10:58am 26 Jan 2015
Don't follow the Rule " Never read the f**king Manual" ;-)
Hihi
atmega8
Posted: 11:00am 26 Jan 2015
Wow,
nice that the Forum Software changed f**king to f**king ;-)
Some kind of "Autoformat", cool 😄
Posted: 02:50am 27 Jan 2015
Most modern forum software is "Slang-aware", and will auto-detect all the common swear words and remove and/or censor them.
Probably not a good idea to use those words in the public forums though - Gizmo(administrator) might smack your hand....
EDIT: I know that even PM's won't allow you to swear, so it must be the forum software text filtering etc.
...not that I was swearing in a PM, or anything like that........ Edited by Grogster 2015-01-28
