Local Time 12:28 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with MMBASIC
Yourock17
Posted: 03:17pm 09 Jan 2015
Hello, I am new to the forum and I have had a little bit of trouble with this fairly simple and annotated program. I have attempted to make a bingo game that announces the numbers on the screen then records them at the bottom of the screen. It is Programed in MMBASIC on the Monochrome Maximite, Firmware is 3.0302. My problem is that (if you have ever played bingo) is that it is putting out the same numbers that it has already put out. I tried to played it with my family, it went for ages. If anyone could give me any ideas that would be nice.
'm is the Maximum Number
't is the Time
'g is the seed
's is the speed
'p is the Pause Length
'a is the final answer
'X is the X axis drawing pos
'Y is the Y axis drawing pos
Cls
Y = 300
M = 90
1 p = 0 'Resets everything ready for the next num.
a = 0
g = 0
t = 0
g = Rnd*m 'Generates A Number
If g < 10 Then g = g+20 'Makes it not slow flashing through numbers
t = t+0.2
a = a+1 'Adds 1 to the scrolling numbers
p = g*t 'Make the pause length slower
a = a Mod m
Pause p
Font 3
Print@(190,190) a
If a < 10 Then Print@(214,190) "."
If p > 400 Then Exit 'If the pause length is 400 Then exit the loop
Loop
Font 1
Print@(X,Y) a
X = X+22 'Starts calculating where to put last bingo num.
If X > 460 Then
Y = Y+15
X = 0
EndIf
Font 2
Print@(135,250,2) "Is The Next Number"
Pause 3000
Print@(135,250) " " 'Gets rid of text when going to another num
Print@(200,200) " "
GoTo 1
Thank youEdited by Yourock17 2015-01-11
halldave
Posted: 05:06pm 09 Jan 2015
Rnd is not a function in mmbasic
you need to use rnd()
Edited by halldave 2015-01-11
ajkw
Posted: 06:11pm 09 Jan 2015
  Yourock17 said   My problem is that (if you have ever played bingo) is that it is putting out the same numbers that it has already put out.
You could use an array to track what numbers have already been drawn in a given game.
if arrayname(drawnnumber) = 1 then redraw
Posted: 07:26pm 09 Jan 2015
For this type of game, I prefer to "shuffle the pack" and then deal the cards out from the top, just like normal cards.
' shuffle the pack
' TassyJim Jan 2015
m = 90 ' maximum size of pack
dim pack(m)
for n = 1 to m ' fill the pack
pack(n) = n ' in this case numbers but could be words etc
next n
for n = m to 1 step -1
' each pass generates a random number from the REMAINING number of cards
k = int(rnd()*n)+1
temp1 = pack(k) ' take a random card from the pack
temp2 = pack(n) ' and swap it with the top of the pack
pack(n) = temp1
pack(k) = temp2
next n
for n = 1 to m
print pack(n)
next n
' now you can select the numbers in turn for
' as many as required knowing the pack has been shuffled
There should be no duplicates and we are not wasting time getting the same number drawn twice.
Yourock17
Posted: 01:02am 12 Jan 2015
  halldave said   g = Rnd*m 'Generates A Number
That works as well, But I'm only 15 and started programming a month ago so im fairly new to it all
I have little knowledge on arrays. I might look into it
Thanks TassyJim for the code but I think I will be good for now.
ajkw
Posted: 02:54am 12 Jan 2015
Pretty good effort for a first month of programming. I have taken the liberty of changing your code to use a array to check if a random number has been drawn already. Let me know if you would like me to post it.
Anthony.
aargee
Posted: 02:04pm 12 Jan 2015
You should have a look at the Randomize command. The random number generator in not truly random (as you are finding).
The best thing to do is ask for a number to seed the Randomize command when you start the program and I would then use the last number of your bingo game to then seed the randomize command for the next game.
You will then be getting a pseudo random number generated, unless of course you always use the same seed number. Often a real time clock or some other continuously changing value is used as a seed.
