Local Time 12:28 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Microcontroller for Fisher Paykel
darcyrandall200
Posted: 09:32pm 03 Jan 2015
Hello,
Does anyone know what brand/model microcontroller is used for the Fischer Paykel washing machine? Can the processor be reprogrammed or is it locked down?
Thankyou.
Regards Darcy Randall, Perth Western Australia
palcal
Posted: 03:43pm 04 Jan 2015
I'm curious as to why you want to know. I used to repair such appliances and I doubt very much if you would be able to reprogram the micro. There would be no provision on the board for in circuit programming and it would be almost impossible to remove it.
Then you would have to identify the chip and find a programmer that would flash it.
Paul.Edited by palcal 2015-01-06
mpep
Posted: 10:45am 05 Jan 2015
  palcal said   I'm curious as to why you want to know. I used to repair such appliances and I doubt very much if you would be able to reprogram the micro. There would be no provision on the board for in circuit programming and it would be almost impossible to remove it.
Paul.
And that all depends on if the micro is indeed reprogrammable. Many companies use OTP types.
darcyrandall200
Posted: 09:34pm 05 Jan 2015
the processor has a heap of io including an A/D converter the ability to drive a motor etc. it would be ideal for all manner of projects not to mention free from the tip
Thankyou.
Posted: 03:19pm 06 Jan 2015
Hi Darcy,
Have you got a picture of one?
Or the text that is written on one of the chips?
Also can you identify the GND/5V/3v3/ lines and anything else that may make it easier to identify?
Like pins the crystal (if any) connect to the freq of that crystal.
Etc. Etc.
It may be a special ie. gate array or anything if its unmarked..
A trick DEC used to do was use standard 74xx series chips but have them packaged upside down (the pins went up instead of down) and they could then re-brand with their own part Numbers..
darcyrandall200
Posted: 06:54pm 06 Jan 2015
I googled the text on the chip but nothing came up. I know companies such as xilinx allow others to print their own labels on the chips.
Thankyou.
Posted: 07:01pm 06 Jan 2015
Hi Darcy,
Any chance of a photo of the chip with legible Numbers/letters? Or at least type out the text itself..
Also the logo if it has any..
To my (failing these days) memory Xilinx were big on Programmable gate arrays and the like that were programmed/configured using FORTRAN so to be able to re-purpose them might be pretty difficult..
darcyrandall200
Posted: 11:06pm 06 Jan 2015
V39 390
0526 321
There are no logos on this chip.
There appears to be a footprint but no connector for what may be a programming port.
EEPROM ST95040
Crystal (Not sure what frequency).
I tried taking a photo but it is far too blury.
Thankyou.
kiiid
Posted: 12:24am 07 Jan 2015
It is a custom micro from Infineon. Not reprogrammable because it is ROM-based.
http://rittle.org
