Local Time 12:20 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Comport Interrrupts..?
Zonker
Posted: 08:34pm 03 Jan 2015
Evening Gents...
I am trying to setup the com port for Rx interrupts but keep
getting an error msg... Error: A sub/fun has the same name
I wanted to use a subroutine to process it
Open"com1:115200,getbuf"As #1
Loop
Sub getbuf
Print Asc(Input$(1,#1))
End Sub
This was just a simple test program, the real one is a bit larger...
Just not sure what I'm doing wrong...
Edited by Zonker 2015-01-05
mpep
Posted: 09:17pm 03 Jan 2015
Someone correct me if I'm wrong, but I believe that Interrupt labels MUST end with :
Just can't find it easily in the manual Edited by mpep 2015-01-05
Posted: 09:21pm 03 Jan 2015
You are missing the receive buffer size:
  Quote  It has the form "COMn: baud, buf, int, intlevel, DE, 9BIT, INV, OC, S2"
It thinks you have the variable "getbuf" the same name as a subroutine.
Posted: 09:22pm 03 Jan 2015
  mpep said   Someone correct me if I'm wrong, but I believe that Interrupt labels MUST end with :
The : is only needed when it is a line label and then only for the actual line label, not with any goto's
mpep
Posted: 09:27pm 03 Jan 2015
Thanks.
