matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11908
Posted: 04:34am 31 Dec 2014
These controllers are appearing on ebay on both 2.8" and 2.4" TFT displays.
I've been working remotely to try and get a 2.4" one working owned by bigmik. I've now got a 2.8" version. Neither of them is working on the MM and I can't even get my one working on Arduino using any of the available online code that is supposed to support it. There are two versions supported by Arduino, 5408A and 5408B. I can only assume these displays use some new different variant.
If you are looking at TFT displays, for the moment I would avoid any that say spfd5408
Posted: 09:14am 01 Jan 2015
More info:
I've finally got my display working on Arduino. Just because the advert says it is a spfd5408 controller doesn't mean that it isn't actually an ILI9341 This of course has a completely different initialisation AND completely different pixel addressing so no wonder it doesn't work with spfd5408 drivers.
I'm 90% there implementing this for MM2 and will post in the display update thread when fully tested.
