Local Time 15:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with 0
edu001
Posted: 10:02am 21 Dec 2014
Hi
I need to selectively remove the 0's from the output of this array, the format is: If the 0 is the first character (0,9,11) it needs to be read so the output is 0,9,11 if the 0 is the second or third character (3,8,0) it needs to be ignored so the output is 3,8
I have tried (with my limited knowlege of BASIC) everything I can think of
Any ideas ?
setpin 21, dout
pin(21) = 0
dim Out$
'''''''''''''''''''''Primary Alphabet
dim STRING A(256) LENGTH 8 'DominoEX16 Primary Alphabet
DATA " 1,15, 9"," 1,15,10"," 1,15,11"," 1,15,12"," 1,15,13"," 1,15,14"," 1,15,15"," 2, 8, 8"
DATA " 2,12, 0"," 2, 8, 9"," 2, 8,10"," 2, 8,11"," 2, 8,12"," 2,13, 0"," 2, 8,13"," 2, 8,14"
DATA " 2, 8,15"," 2, 9, 8"," 2, 9, 9"," 2, 9,10"," 2, 9,11"," 2, 9,12"," 2, 9,13"," 2, 9,14"
DATA " 2, 9,15"," 2,10, 8"," 2,10, 9"," 2,10,10"," 2,10,11"," 2,10,12"," 2,10,13"," 2,10,14"
DATA " 0, 0, 0"," 7,11, 0"," 0, 8,14"," 0,10,11"," 0, 9,10"," 0, 9, 9"," 0, 8,15"," 7,10, 0"
DATA " 0, 8,12"," 0, 8,11"," 0, 9,13"," 0, 8, 8"," 2,11, 0"," 7,14, 0"," 7,13, 0"," 0, 8, 9"
DATA " 3,15, 0"," 4,10, 0"," 4,15, 0"," 5, 9, 0"," 6, 8, 0"," 5,12, 0"," 5,14, 0"," 6,12, 0"
DATA " 6,11, 0"," 6,14, 0"," 0, 8,10"," 0, 8,13"," 0,10, 8"," 7,15, 0"," 0, 9,15"," 7,12, 0"
DATA " 0, 9, 8"," 3, 9, 0"," 4,14, 0"," 3,12, 0"," 3,14, 0"," 3, 8, 0"," 4,12, 0"," 5, 8, 0"
DATA " 5,10, 0"," 3,10, 0"," 7, 8, 0"," 6,10, 0"," 4,11, 0"," 4, 8, 0"," 4,13, 0"," 3,11, 0"
DATA " 4, 9, 0"," 6,15, 0"," 3,13, 0"," 2,15, 0"," 2,14, 0"," 5,11, 0"," 6,13, 0"," 5,13, 0"
DATA " 5,15, 0"," 6, 9, 0"," 7, 9, 0"," 0,10,14"," 0,10, 9"," 0,10,15"," 0,10,10"," 0, 9,12"
DATA " 0, 9,11"," 4, 0, 0"," 1,11, 0"," 0,12, 0"," 0,11, 0"," 1, 0, 0"," 0,15, 0"," 1, 9, 0"
DATA " 0,10, 0"," 5, 0, 0"," 2,10, 0"," 1,14, 0"," 0, 9, 0"," 0,14, 0"," 6, 0, 0"," 3, 0, 0"
DATA " 1, 8, 0"," 2, 8, 0"," 7, 0, 0"," 0, 8, 0"," 2, 0, 0"," 0,13, 0"," 1,13, 0"," 1,12, 0"
DATA " 1,15, 0"," 1,10, 0"," 2, 9, 0"," 0,10,12"," 0, 9,14"," 0,10,12"," 0,11, 8"," 2,10,15"
DATA " 2,11, 8"," 2,11, 9"," 2,11,10"," 2,11,11"," 2,11,12"," 2,11,13"," 2,11,14"," 2,11,15"
DATA " 2,12, 8"," 2,12, 9"," 2,12,10"," 2,12,11"," 2,12,12"," 2,12,13"," 2,12,14"," 2,12,15"
DATA " 2,13, 8"," 2,13, 9"," 2,13,10"," 2,13,11"," 2,13,12"," 2,13,13"," 2,13,14"," 2,13,15"
DATA " 2,14, 8"," 2,14, 9"," 2,14,10"," 2,14,11"," 2,14,12"," 2,14,13"," 2,14,14"," 2,14,15"
DATA " 0,11, 9"," 0,11,10"," 0,11,11"," 0,11,12"," 0,11,13"," 0,11,14"," 0,11,15"," 0,12, 8"
DATA " 0,12, 9"," 0,12,10"," 0,12,11"," 0,12,12"," 0,12,13"," 0,12,14"," 0,12,15"," 0,13, 8"
DATA " 0,13, 9"," 0,13,10"," 0,13,11"," 0,13,12"," 0,13,13"," 0,13,14"," 0,13,15"," 0,14, 8"
DATA " 0,14, 9"," 0,14,10"," 0,14,11"," 0,14,12"," 0,14,13"," 0,14,14"," 0,14,15"," 0,15, 8"
DATA " 0,15, 9"," 0,15,10"," 0,15,11"," 0,15,12"," 0,15,13"," 0,15,14"," 0,15,15"," 1, 8, 8"
DATA " 1, 8, 9"," 1, 8,10"," 1, 8,11"," 1, 8,12"," 1, 8,13"," 1, 8,14"," 1, 8,15"," 1, 9, 8"
DATA " 1, 9, 9"," 1, 9,10"," 1, 9,11"," 1, 9,12"," 1, 9,13"," 1, 9,14"," 1, 9,15"," 1,10, 8"
DATA " 1,10, 9"," 1,10,10"," 1,10,11"," 1,10,12"," 1,10,13"," 1,10,14"," 1,10,15"," 1,11, 8"
DATA " 1,11, 9"," 1,11,10"," 1,11,11"," 1,11,12"," 1,11,13"," 1,11,14"," 1,11,15"," 1,12, 8"
DATA " 1,12, 9"," 1,12,10"," 1,12,11"," 1,12,12"," 1,12,13"," 1,12,14"," 1,12,15"," 1,13, 8"
DATA " 1,13, 9"," 1,13,10"," 1,13,11"," 1,13,12"," 1,13,13"," 1,13,14"," 1,13,15"," 1,14, 8"
DATA " 1,14, 9"," 1,14,10"," 1,14,11"," 1,14,12"," 1,14,13"," 1,14,14"," 1,14,15"," 1,15, 8"
for B = 0 to 255
read A(B)
next B
getsym
sub getsym
do
Out$ = "EDUPIC DOMINOEX TEST" 'Turn Out$ into ASCII (txtchr)
for t = 1 to len(Out$)
txtchr=Asc(Mid$(Out$, t, 1))
'Use txtchr value to read the arrays
syma = val(LEFT$(mid$(A(txtchr), 1), 2))
symb = val(left$(mid$(A(txtchr), 4), 2))
symc = val(right$(mid$(A(txtchr), 1), 2))
next t
loop
Jed
Posted: 10:59am 21 Dec 2014
There are many ways to achieve what you are after.
With the code you have posted here, I would keep the zero's.
When you call the sub that outputs the tones, only call it if the value is greater than zero for the second and third sym.
do
maketone syma ' always send this one
if symb > 0 then maketome symb ' only send if not zero
if symc > 0 then maketome symc ' only send if not zero
next t
loop
sub maketone symbol
' do whatever to generate tones
end sub
Not the most efficient code but good enough to get to the next step - making noise.
edu001
Posted: 09:44pm 21 Dec 2014
Thanks TassyJim
If I needed to output the array values directly that would work
I should have mentioned that there is a step in between reading the array and creating the tones I have to do this calculation
Output = (Previous output +2 +value read from array) MOD 18
So the idea was to filter out the zero's
Read the values of syma, symb, symc into an array (don,t know how yet) call it sym
Then out = (out +2 +sym) MOD 18
Am I approaching the whole thing in the wrong way ?
