Local Time 15:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ASCII Terminal MX150?
vk2sja
Posted: 06:45pm 20 Dec 2014
Hi All,
I just starting an ASCII Terminal build. But discover that the only 32 bit PIC micros that I have on hand are PIC32MX150F128B-50I/SP. Which "I think" I ordered in for building Micromite's (haven't got to that yet).
Looking at the the ASCII Terminal documentation it calls for a PIC32MX250F128B-I/SP.
Quick look at the data-sheets and one of the differences is USB OTG support (250 has 150 does not). Anyway can someone set me straight. Can I get away with my MX150F or (as I fear) must I order in some MX250F chips?
Steve.
Posted: 06:57pm 20 Dec 2014
I think I read that someone else had used the 150's for the VT100 - you just can't have any USB side of things, but it does work on the 150's from what I remember reading.
Others here will confirm that.....
cosmic frog
Posted: 12:48am 21 Dec 2014
Yes you can. I use the 150 and it works but without the USB.
Dave.
vk2sja
Posted: 06:43pm 21 Dec 2014
  cosmic frog said   Yes you can. I use the 150 and it works but without the USB.
Dave.
Thanks Dave and Grogster,
Too close to Christmas now to get the MX250 so it's good to know that I can get away with the 150 over the break. I'm using it for a P112 CP/M machine via serial port. So won't miss the USB functionality in the short term.
Merry Christmas All,
Steve.
Posted: 10:26pm 21 Dec 2014
Gday Steve,
whereabouts in AUS are you? I am in Melbourne if you need a 250 quickly
vk2sja
Posted: 12:29pm 22 Dec 2014
  bigmik said   Gday Steve,
Hi Mick,
Thanks for the offer but we're all good. I'll use the MX150 over the Break and truly I only need the TTL serial for this particular application. I'll order in some MX250's in the New Year and upgrade just so that I've got complete functionality when I do want to use the USB side of things.
Nowra, New South. BTW.
Cheers Steve.
