Local Time 11:39 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: 2.4" colour screen updated software
Posted: 03:08am 15 Dec 2014
Based on the changes I made to text handling on the 1.8" screen I've retrofitted these to the 2.4" screen - basically converting the pstring function to C. Complete screen write of 8x6 pixel characters (1600 characters on the 240x320 display) has been reduced from over 5 seconds to 660msec.
It should be noted that these screens require both a 5V and 3.3V supply. The backlight doesn't come on with 3.3V.
2014-12-15_130401_T24BAS.zip
viscomjim
Posted: 03:56am 15 Dec 2014
Hi Matherp, could you give an example of which screen you are using for this? Thanks!!!!
Posted: 05:19am 15 Dec 2014
Here you go:
Example
Posted: 05:50am 15 Dec 2014
Hmmm.. :)
Touchscreen..... MicroSD......
Interesting....
