Local Time 11:39 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Cfunction request: Additional console RX
Oldbitcollector
Posted: 09:27am 08 Dec 2014
I'm not even sure if this is possible with Cfunctions, but since I'm still getting my head wrapped around the basics of Cfunctions, I could use some help.
I need a Cfunction that will allow me to accept (Rx) serial data from another pin and send it into the console. (Allowing incoming control data from two sources at the same time {console and an additional pin) Either this is impossible, or I'm over thinking something that is simple. (not sure)
Jeff
My Propeller/Micromite mini-computer project.
G8JCF
Posted: 09:56am 08 Dec 2014
There is a CFunction, SerialRX - see http://www.g8jcf.dyndns.org/MMBasicIILib/ which enables a program to receive input from a pin and pass that data back to the calling MMBasic program, which could then PRINT that data to the console.
Even simpler if you can use COM1: or COM2:, then it's all standard MMBasic to read characters off COM1/2 and PRINT them out to the Console - No CFunction required.
Is that what you want
PeterEdited by G8JCF 2014-12-09
The only Konstant is Change
Oldbitcollector
Posted: 12:10pm 08 Dec 2014
I guess what I was really trying to do was change the function of another pin to perform the same job as a console pin which operates without having a program actually "running" in memory. I'm guessing this is well outside of a Cfunction task.
G8JCF
Posted: 12:18pm 08 Dec 2014
A CFunction must be called from MMBasic, so that means there must be a MMBasic program to start with, and it must have run so as to invoke the CFunction.
The Console port is treated very specially by MMBasic hence I could imagine that moving the Console to another set of pins would be extremely non-trivial !
It maybe that someone, (and I'm definitely not clued up enough to do this), may find a way of using interrupts to call a CFunction so that even though the MMBasic program wasn't actually running (but clearly it must be loaded), the PIC32 would vector to the CFunction on interrupt from a pin.
Peter
Posted: 01:04pm 08 Dec 2014
Perhaps this is a case of x divided by zero so to speak - not possible?
I'm trying to understand why you would need to have things setup like this.
Could you please enlighten me?
