Local Time 12:29 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 4.6b26: new SPI WRITE FOR Nokia5110
Posted: 04:50am 07 Dec 2014
In a previous thread we discussed how i2c could be faster than SPI on the Micromite as it could output multiple bytes in a single Basic transaction.
In 4.6B26 Geoff has included a new multibyte SPI WRITE statement. This transforms the discussion. I've attached a simple clock/thermometer demo of my graphics routines using an SPI NOKIA 5110 display, DS18B20, and the DS3231 RTC. I'm waiting for delivery of a SPI version of the SSD1306 and will post revised routines for that display once converted.
Complete screen refresh on the NOKIA now takes only 20msec and the more limited refreshes while the program is running are taking 2-8msec depending on the number of characters that have changed.
My wish list for the Micromite Mk2 is now pretty much empty. Huge thanks and congratulations should go to Geoff for what he has achieved with the new Micromite. Personally, my projects will now all be either Micromite-based or 8-pin PIC or PICAXE. I can't see any reason to use anything else
Peter
' V1.0
' Monochrome Port of Adafruit graphics library with drivers for SPI NOKIA 5110 display
' drawing primitives assume a graphics display where top left is point 0,0
' set screen orientation: sub setrot(x) ;0=normal,1=invert,2=rotate right,3-rotate left
' draw circle: sub dcirc(x0,y0,r) ;x,y coordinates of centre,radius
' draw filled circle: sub fcirc(x0,y0,r) ;x,y coordinates of centre,radius
' draw triangle: sub dtri(x0,y0,x1,y1, x2,y2) ;three coordinate pairs
' draw filled triangle sub ftri (x0,y0,x1,y1, x2,y2) ;three coordinate pairs
' print string: sub pstring(xx0,yy0,text$,sz,orientation) ;x,y coordinates of top left of first character,text string,size,orientation
' draw line: sub dLine(xx0,yy0,xx1,yy1) ;x,y of start line,x,y of end line
' draw rectangle: sub dRect(x,y,w,h) ;x,y coordinate of top left,width,height
' draw filled rectangle: sub frect(x,y,w,h) ;x,y coordinate of top left,width,height
' clear rectangle: sub crect(x,y,w,h) ;x,y coordinate of top left,width,height
' draw rounded rectangle: sub drndRect(x,y,w,h,r) ;x,y coordinates of top left,width,height,radius of corner
' draw filled rounded rectangle: sub frndRect(x,y,w,h,r) ;x,y coordinates of top left,width,height,radius of corner
' These routines just update the memory image of the display
' Use the refresh command to write to the display as required
cpu 48
OPTION EXPLICIT
OPTION DEFAULT integer
'option autorun on
const normal=0
const inverse=1
const rt_right=2
const rt_left=3
const ON=&B1
const OFF=&B0
const pix=0
const ffr=1
const drawchar=2
const drawline=3
' pin assignments for Nokia 5110
const N_RST=24
const N_CE=23
const N_DC=15
const N_Datain=3
const N_CLK=25
const N_VCC=7
' pin for DS18B20
const DSpin=26
' Global variables
dim wi,ht,nr,i2caddr,rot_ht,rot_wi,sz,rot,AddrOfFont
dim sc(128),dd(128) 'set up arrays for screen map to mimic display
init:
initNdisplay 'initialise the display
AddrOfFont=PEEK(CFunAddr FONT) '
setrot(normal)
DSgettime
n_clearsc
dim temperature as float
dim as string year$,month$,day$,hour$,min$,sec$,tempstr$,degrees$,fraction s$
settick 600000,settime,4 'update the clock every 10 minutes
temperature=ds18b20(26)
ds18b20 start DSpin,1
tempstr$=str$(temperature,2,2)
drndrect(0,0,wi,ht,9)
pstring(15,5,date$,1,normal)
pstring(19,15,time$,1,normal)
pstring(9,28,tempstr$+chr$(247),2,normal)
n_refresh
Main:
do
temperature=ds18b20(DSpin)
do
loop while right$(time$,2)=sec$
sec$=righT$(time$,2)
pstring(55,15,sec$,1,normal)
if left$(time$,2)<>hour$ THEN
hour$=LEFT$(time$,2)
pstring(19,15,hour$,1,normal)
endif
if mid$(time$,4,2)<>min$ THEN
min$=mid$(time$,4,2)
pstring(37,15,min$,1,normal)
endif
n_refresh
if left$(DATE$,2)<>day$ THEN
day$=LEFT$(DATE$,2)
pstring(15,5,day$,1,normal)
endif
if mid$(DATE$,4,2)<>month$ THEN
month$=mid$(DATE$,4,2)
pstring(33,5,month$,1,normal)
endif
if right$(DATE$,4)<>year$ THEN
year$=righT$(DATE$,4)
pstring(51,5,year$,1,normal)
endif
if left$(tempstr$,3)<>degrees$ then
degrees$=left$(tempstr$,2)
pstring(9,28,degrees$,2,normal)
endif
if fractions$<>right$(tempstr$,2) then
fractions$=right$(tempstr$,2)
pstring(45,28,fractions$,2,normal)
endif
n_refresh
loop
end
settime:
print time$," ";
DSgettime
print time$
ireturn
sub DSSettime
local clock$
local i
local i2clook=peek(WORD &HBF805000) AND &H8000
if not i2clook then i2c open 400,1000
i=rtcsetDS(clock$,time$,date$)
I2C write &b1101000,0,len(clock$),clock$
if not i2clook then i2c close
end sub
sub DSGettime
local clock$ ,DSdate$ ,DStime$
I2C WRITE &b1101000,1,1,0 'set the read address to 0
I2C READ &b1101000,0,7,clock$
local i=rtcgetDS(clock$,DStime$,DSdate$)
time$=dstime$
date$=dsdate$
end sub
' Nokia 5110 Display specific routines
sub initNdisplay
wi=84
ht=48
nr=6
setpin N_RST, dout
SETPIN N_CE, DOUT
SETPIN N_DC, DOUT
SETPIN N_VCC, DOUT
spi open 6000000,3,8
PIN(N_VCC)=0 'turn off display power
pause 500
pin(N_RST)=1 'set RESET high
PIN(N_VCC)=1 'Turn on the power
PIN(N_RST)=0
PIN(N_RST)=1 'reset the display
N_SendCommand(&H21)'N_EXTENDED_COMMAND
N_SendCommand(&H05)'N_TEMP_COEFFICIENT
N_SendCommand(&H14)'N_BIAS
N_SendCommand(&H20)'N_BASIC_COMMAND
N_SendCommand(&H0C)'N_D_NORMAL
N_ClearSc
N_SendCommand(&HB2)'N_CONTRAST = &HB2 :adjust for individual display
end sub
sub N_refresh
local startrow,startcol,rst
local outchar$ length 130
do
rst=Ngetnextupdate(outchar$,startcol,startrow,wi,nr,sc(),dd( ))
if rst<>0 then
N_cursor(startcol,startrow)
pin(N_DC)=1 'set for sending data
pin(N_CE)=0
spi write len(outchar$),outchar$
pin(N_CE)=1
endif
loop while rst<>0
end sub
Sub N_SendCommand(command)
local i
pin(N_DC)=0 ' Send this byte as a command
PIN(N_CE)=0
spi write 1,command
PIN(N_CE)=1
end sub
Sub N_ClearSc
local j
for j=0 to wi-1
sc(j)=0
dd(j)=-1
next j
N_refresh
end sub
sub N_Cursor(x,y)
N_SendCommand(x or &H80)' N_xcursor
N_SendCommand(y OR &H40)' N_ycursor
end sub
' Generic drawing routines
sub dcirc(x0 ,y0 ,r ) 'x,y coordinates of centre,radius
local f=1-r,ddF_x=1,ddF_y=-2 * r,x=0,y=r,dp
dp=draw(pix,sc(),ON,x0,y0+r,rot,wi,ht)
dp=draw(pix,sc(),ON,x0,y0-r,rot,wi,ht)
dp=draw(pix,sc(),ON,x0+r,y0,rot,wi,ht)
dp=draw(pix,sc(),ON,x0-r,y0,rot,wi,ht)
do while (x<y)
if f>=0 then
y=y-1
ddF_y=ddF_y+2
f=f+ddF_y
endif
x=x+1
ddF_x=ddF_x+2
f=f+ddF_x
dp=draw(pix,sc(),ON,x0+x,y0+y,rot,wi,ht)
dp=draw(pix,sc(),ON,x0-x,y0+y,rot,wi,ht)
dp=draw(pix,sc(),ON,x0+x,y0-y,rot,wi,ht)
dp=draw(pix,sc(),ON,x0-x,y0-y,rot,wi,ht)
dp=draw(pix,sc(),ON,x0+y,y0+x,rot,wi,ht)
dp=draw(pix,sc(),ON,x0-y,y0+x,rot,wi,ht)
dp=draw(pix,sc(),ON,x0+y,y0-x,rot,wi,ht)
dp=draw(pix,sc(),ON,x0-y,y0-x,rot,wi,ht)
loop
end sub
sub dtri(x0 ,y0 ,x1 ,y1 , x2 ,y2 ) 'three coordinate pairs
dLine(x0,y0,x1,y1)
dLine(x1,y1,x2,y2)
dLine(x2,y2,x0,y0)
end sub
sub ftri (x0 ,y0 ,x1 ,y1 , x2 ,y2 ) 'three coordinate pairs
local a,b,y,dp,last
if (y0>y1) then
swap(y0,y1)
swap(x0,x1)
endif
if (y1>y2) then
swap(y2,y1)
swap(x2,x1)
endif
if (y0>y1) then
swap(y0,y1)
swap(x0,x1)
endif
if(y0=y2) then ' Handle awkward all-on-same-line case as its own thing
a=x0
b=x0
if(x1<a) then
a=x1
else
if(x1>b) then b=x1
endif
if(x2<a) then
a=x2
else
if(x2>b) then b=x2
endif
dp=draw(ffr,sc(),ON,a,y0,1,b-a+1,rot,wi,ht)
exit sub
endif
local dx01=x1-x0, dy01=y1-y0, dx02=x2-x0, dy02=y2-y0,dx12=x2-x1, dy12=y2-y1, sa=0,sb=0
if(y1=y2) then
last=y1 'Include y1 scanline
else
last=y1-1 ' Skip it
endif
for y=y0 to last
a=x0+sa \ dy01
b=x0+sb \ dy02
sa=sa+dx01
sb=sb+dx02
a=x0+(x1-x0) * (y-y0) \ (y1-y0)
b=x0+(x2-x0) * (y-y0) \ (y2-y0)
if(a>b) then swap(a,b)
dp=draw(ffr,sc(),ON,a,y,b-a+1,1,rot,wi,ht)
next y
sa=dx12 * (y-y1)
sb=dx02 * (y-y0)
do while y<=y2
a=x1+sa \ dy12
b=x0+sb \ dy02
sa=sa+dx12
sb=sb+dx02
a=x1+(x2-x1) * (y-y1) \ (y2-y1)
y=y+1
loop
end sub
sub pstring(xx0 ,yy0 ,text$ as string,sz ,orientation ) 'x,y coordinates of top left of first character,text string,size,orientation
local i,c,x=xx0,y=yy0,chr0,dp
for i=1 to len(text$)
c=asc(mid$(text$,i,1))
chr0=getchar(c) 'loads the character
dp=draw(drawchar,sc(),chr0,x,y,sz,orientation,rot,wi,ht)
on orientation+1 goto pnormal,pinvert,prtright,prtleft
pnormal:
x=x+(6*sz)
goto pcontinue
pinvert:
x=x-(6*sz)
goto pcontinue
prtright:
y=y+(6*sz)
goto pcontinue
prtleft:
y=y-(6*sz)
pcontinue:
next i
xx0=x
yy0=y
end sub
sub dLine(xx0 ,yy0 ,xx1 ,yy1 ) ' x,y of start line,x,y of end line
local dp=draw(drawline,sc(),ON,xx0,yy0,xx1,yy1,rot,wi,ht)
end sub
sub swap (a ,b )
local t
t=b
b=a
a=t
end sub
sub dRect(x ,y ,w ,h ) 'x,y coordinate of top left,wi,ht
local a,dp
dp=draw(ffr,sc(),ON,x,y,w,1,rot,wi,ht)
a=y+h-1
dp=draw(ffr,sc(),ON,x,a,w,1,rot,wi,ht)
dp=draw(ffr,sc(),ON,x,y,1,h,rot,wi,ht)
a=x+w-1
dp=draw(ffr,sc(),ON,a,y,1,h,rot,wi,ht)
end sub
sub frect(x ,y ,w ,h ) 'x,y coordinate of top left,width,height
local dp
dp=draw(ffr,sc(),ON,x,y,w,h,rot,wi,ht)
end sub
sub crect(x ,y ,w ,h ) 'x,y coordinate of top left,width,height
local dp
dp=draw(ffr,sc(),OFF,x,y,w,h,rot,wi,ht)
end sub
FUNCTION Getchar(char )
local i=char<<3
Getchar=PEEK(WORD AddrOfFont+i)+(PEEK(WORD AddrOfFont+i+4)<<32)
END FUNCTION
sub fcirc(x0 ,y0 ,r ) 'x,y coordinates of centre,radius
local dp
dp=draw(ffr,sc(),ON,x0,y0-r,1,2*r+1,rot,wi,ht)
fcircH(x0,y0,r,3,0);
end sub
sub drndRect(x ,y ,w ,h ,r ) 'x,y coordinates of top left,width,height,radius of corner
local dp
dp=draw(ffr,sc(),ON,x+r,y,w-2*r,1,rot,wi,ht)
dp=draw(ffr,sc(),ON,x+r,y+h-1,w-2*r,1,rot,wi,ht)
dp=draw(ffr,sc(),ON,x,y+r,1,h-2*r,rot,wi,ht)
dp=draw(ffr,sc(),ON,x+w-1,y+r,1,h-2*r,rot,wi,ht)
dcircH(x+r,y+r,r,1)
dcircH(x+w-r-1,y+r,r,2)
dcircH(x+w-r-1,y+h-r-1,r,4)
dcircH(x+r,y+h-r-1,r,8)
end sub
sub dcircH( x0 ,y0 ,r ,cn )
do while (x<y)
if (f>=0) then
y=y-1
ddF_y=ddF_y+2
f=f+ddF_y
endif
x=x+1
ddF_x=ddF_x+2
f=f+ddF_x
if (cn and 4) then
endif
if (cn and 2) then
endif
if (cn and 8) then
endif
if (cn and 1) then
endif
loop
end sub
sub fcircH(x0 ,y0 ,r ,cn ,delta )
local dp,f=1-r,ddF_x=1,ddF_y=-2 * r,x=0,y=r
do while x<y
if f>=0 then
y=y-1
ddF_y=ddF_y+2
f=f+ddF_y
endif
x=x+1
ddF_x=ddF_x+2
f=f+ddF_x
if (cn and 1) then
dp=draw(ffr,sc(),ON,x0+x,y0-y,1,2*y+1+delta,rot,wi,ht)
dp=draw(ffr,sc(),ON,x0+y,y0-x,1,2*x+1+delta,rot,wi,ht)
endif
if (cn and 2) then
dp=draw(ffr,sc(),ON,x0-x,y0-y,1,2*y+1+delta,rot,wi,ht)
dp=draw(ffr,sc(),ON,x0-y,y0-x,1,2*x+1+delta,rot,wi,ht)
endif
loop
end sub
sub frndRect(x ,y ,w ,h ,r ) 'x,y coordinates of top left,width,height,radius of corner
local dp
dp=draw(ffr,sc(),ON,x+r,y,w-2*r,h,rot,wi,ht)
fcircH(x+w-r-1,y+r,r,1,h-2*r-1)
fcircH(x+r,y+r,r,2,h-2*r-1)
end sub
sub setrot(x ) 'sets screen rotation: 0=normal,1=invert,2=rotate right,3-rotate left
rot=(x and 3)
rot_wi=wi
rot_ht=ht
if x>=2 then
rot_wi=ht
rot_ht=wi
endif
end sub
' CFunctions
CFunction rtcsetDS
00000000
24020011 a0820000 a0800001 90a20007 2442ffd0 00021100 90a30008
2463ffd0 00431025 a0820002 90a20004 2442ffd0 00021100 90a30005 2463ffd0
00431025 a0820003 90a20001 2442ffd0 00021100 90a30002 2463ffd0 00431025
a0820004 24020001 a0820005 90c20001 2442ffd0 00021100 90c30002 2463ffd0
00431025 a0820006 90c20004 2442ffd0 00021100 90c30005 2463ffd0 00431025
a0820007 90c20009 2442ffd0 00021100 90c3000a 2463ffd0 00431025 a0820008
a0800009 a080000a a080000b a080000c a080000d a080000e 24020004 a082000f
a0800010 00001021 03e00008 00001821
End CFunction
CFunction rtcgetDS
00000000
90820001 3042000f 24420030 a0a20008 90820001 00021102 24420030 a0a20007
2402003a a0a20006 90830002 3063000f 24630030 a0a30005 90830002 00031902
24630030 a0a30004 a0a20003 90820003 3042000f 24420030 a0a20002 90820003
00021102 24420030 a0a20001 24020008 a0a20000 2402000a a0c20000 90820005
3042000f 24420030 a0c20002 90820005 00021102 24420030 a0c20001 2402002d
a0c20003 90830006 3063000f 24630030 a0c30005 90830006 00031902 24630030
a0c30004 a0c20006 90820007 3042000f 24420030 a0c2000a 90820007 00021102
24420030 a0c20009 24020032 a0c20007 24020030 a0c20008 00001021 03e00008
00001821
End CFunction
CFunction Ngetnextupdate
00000000
27bdffa8 afb00054 8fb80068 8faf006c 8f090000 1120000c 8fae0070 00094880
00001021 2403ffff 27aa0010 01424021 ad030000 27b00030 02024021 24420004
1449fffa ad030000 8ce20000 1040002a 00004021 8f190000 00005821 240dffff
000840c0 01e81021 8c430004 8c420000 afa20000 afa30004 01c84021 8d020000
8d030004 afa20008 13200016 afa3000c 8f0c0000 27a30010 27a80030 00001021
03a25021 27b00008 02024821 914a0000 91290000 51490007 24420001 8c690000
552d0003 ad0b0000 ac6b0000 ad0b0000 24420001 24630004 004c482b 1520fff0
25080004 256b0001 8ce20000 0162102b 1440ffdb 01604021 8f020000 2442ffff
00004021 04400036 00004821 00021880 27a70010 00e31821 2407ffff 2409ffff
8c680000 01094026 0048380b 2442ffff 0441fffb 2463fffc 00004021 2402ffff
10e20027 00004821 00071080 03a21021 8c4b0010 acab0000 8c4c0030 018b102a
1440001b 00002821 000b10c0 01e27821 01c27021 03a75021 8de20000 8de30004
afa20000 afa30004 8dc20000 8dc30004 afa20008 afa3000c 24a50001 91420000
a1420008 00851821 a0620000 8fa20008 8fa3000c adc20000 adc30004 25ef0008
01651021 0182102a 1040ffeb 25ce0008 acc70000 a0850000 00a04021 00054fc3
01001021 01201821 8fb00054 03e00008 27bd0058
End CFunction
CFunction draw
'localfastfillrect
000006B4
27bdffa0 afbe005c afb70058 afb60054 afb50050 afb4004c afb30048 afb20044
afb10040 afb0003c 8fb80070 8fae0074 8fb10078 8fb9007c 8fb40080 8fb50084
8fa90088 afa90028 8fb6008c 8fad0090 8faf0094 8fb20098 8fa9009c 8fb300a0
8fb000a4 2417ffff a3b70008 241efffe a3be0009 241efffc a3be000a 241efff8
a3be000b 241efff0 a3be000c 241effe0 a3be000d 241effc0 a3be000e 241eff80
a3be000f 241e0001 a3be0010 241e0003 a3be0011 241e0007 a3be0012 241e000f
a3be0013 241e001f a3be0014 241e003f a3be0015 241e007f a3be0016 a3b70017
01afb825 56e0003d 24170001 01c9102a 14400007 2702ffff 152e01d3 00001021
0312102b 104001d0 00001021 2702ffff 0058282b 25c3ffff 00a32821 00541821
0062102b 00b52821 00451021 00402821 0049102a 1440000a 00606021 55250005
264cffff 0072182b 14600006 0330102a 264cffff 0192282b 2522ffff 00a22821
0330102a 14400007 2622ffff 161901b6 00001021 0233102b 104001b3 00001021
2622ffff 0051402b 2723ffff 01034021 8faa0028 004a1821 0062102b 01164021
00481021 00404021 0050102a 144001a8 afa30020 56080005 266cffff 0073182b
546001a4 02201021 266cffff 0193282b 2602ffff 1000019e 00a22821 55b70035
24170002 55e00033 24170002 0018c027 000e7027 03129021 0258c02b 01c94821
03094821 02406021 0520018e 01202821 00118827 0019c827 02339821 0271882b
03308021 02308021 afb30020 06000185 02004021 24020001 0054a023 0054102b
01224823 02929021 0254a02b 0135a823 02955021 000a1fc3 00037827 000fc7c3
02581024 01581824 00405821 00605021 24020001 8fad0028 004d4823 0049102b
02028023 01339821 0269482b 0216b023 01366821 000d7fc3 000fc827 001987c3
02707024 01b07824 01c01021 1000008e 01e01821 55b7004f 24170003 55e0004d
24170003 00111827 00192827 00721021 0043182b 00a92821 00651821 00602821
0069182a 1460000a 00406021 55250005 264cffff 0052102b 14400006 24020001
264cffff 0192282b 2522ffff 00a22821 24020001 8faa0028 004a4023 0048102b
00a21023 010c1821 0068402b 00561023 00605821 01025021 000a47c3 000a1827
afa30030 00084027 afa80034 00081fc3 afa30020 afa30024 01631024 01431824
00405821 01d0102a 14400006 00605021 160e0135 00001021 0313102b 10400132
00001021 2702ffff 0058402b 25c3ffff 01034021 00541821 0062102b 01154021
00481021 00404021 0050102a 1440000e afa30020 16080005 2662ffff 0073182b
5460000a 03001021 2662ffff 0053402b 2603ffff afa20020 01034021 03001021
10000003 01c01821 03001021 01c01821 24170003 55b7003d 0003c7c3 55e0003b
0003c7c3 0329102a 14400007 2622ffff 1539010d 00001021 0232102b 1040010a
00001021 2622ffff 0051282b 2723ffff 00a32821 8faa0028 004a1821 0062102b
00b6b021 00561021 00402821 0049102a 1440000a 00606021 55250005 264cffff
0072182b 54600006 0018c027 264cffff 0192282b 2529ffff 00a92821 0018c027
000e7027 03139821 0278c02b 01d08021 03108021 afb30020 060000ea 02004021
24020001 0054a023 0054102b 02028023 02939821 0274a02b 0215a823 02954821
02601021 05200004 01201821 02205821 10000005 03205021 02205821 03205021
00001021 00001821 0003c7c3 33180007 0302a021 0298c02b 0303c021 00184f40
0014a0c2 0134a025 0018c0c3 0280c821 00086fc3 31ad0007 8faf0020 01af4821
012d682b 01a84021 00086f40 000948c2 01a94825 0008b0c3 01208821 02c0f021
0014a0c0 0054a023 000948c0 01e94823 17310038 afa90020 17160037 27350001
00aa102a 14400035 02b9b82b 15450004 000b68c0 018b102b 14400031 02f8b821
008d6821 01607021 01407821 00c7b825 03b98021 8fa20020 03a2a821 03b49821
01a09021 8da20000 8da30004 afa20000 12e00008 afa30004 92a30010 92620008
00621024 92030000 00431025 10000008 a2020000 92a30010 92620008 00621024
00021027 92030000 00431024 a2020000 8fa80000 8fa90004 ae480000 ae490004
25c20001 004e702b 01cf1821 00407021 00607821 00a3182a 14600006 25ad0008
15e5ffe0 01a09021 0182102b 5040ffde 8da20000 27350001 02b9b82b 02f8b821
02a06821 02d7102a 14400041 02e0c021 16fe0005 00aa102a 0235102b 5440003d
02f6b02a 00aa102a 5440003a 02f6b02a 15450004 000b18c0 018b102b 54400035
02f6b02a 00831821 01607021 01407821 00c79025 03b91021 03b4a021 03b1c821
8fa80020 03a89821 00608021 8c680000 8c690004 afa80000 1240000a afa90004
92890008 90480000 01284025 a0480000 92690010 93280000 01284025 1000000b
a3280000 92880008 00084027 90490000 01094024 a0480000 92680010 00084027
93290000 01094024 a3280000 8fa80000 8fa90004 ae080000 ae090004 25c80001
010e702b 01cf4821 01007021 01207821 00a9482a 15200006 24630008 15e5ffdb
00608021 0188402b 5100ffd9 8c680000 02f6b02a 56c00006 03b5a821 57d80042
8fbe005c 02b1102b 10400034 03b5a821 00aa782a 000b10c0 00822021 00c73025
2407ffff 10000023 018bc82b 01008021 8d020000 8d030004 afa20000 10c00003
afa30004 10000002 a2a70000 a2a00000 8fa20000 8fa30004 ae020000 ae030004
25220001 0049482b 012e1821 00404821 00607021 00a3182a 14600006 25080008
15c5ffeb 01008021 0182102b 5040ffe9 8d020000 25a20001 004d182b 00406821
0078c021 14510003 26b50001 531e0016 8fbe005c 15e0fff8 25a20001 55450004
00804021 1720fff5 004d182b 00804021 01604821 1000ffd5 01407021 1000000a
8fbe005c 00001021 10000006 00001821 02201021 03201821 03005821 1000fee4
01c05021 8fbe005c 8fb70058 8fb60054 8fb50050 8fb4004c 8fb30048 8fb20044
8fb10040 8fb0003c 03e00008 27bd0060
'localdrawPixel
27bdfff8 afb10004 afb00000 8fb80018
8faf001c 8fae0020 8fad0024 8fa30028 8fab002c 8fb00030 8faa0034 8fb10038
006bc825 17200006 8fac003c 03004821 01e01021 01c04021 10000020 01a02821
24190001 14790010 24190002 1560000e 00000000 0018c027 000f7827 03104821
0138c02b 01ea7821 030f1021 000e7027 000d6827 01d14021 010e702b 01ac6821
1000001a 01cd2821 1479000d 24190003 1560000b 00000000 03004021 01e02821
000e7027 000d6827 01d04821 012e702b 01aa6821 1000000d 01cd1021 24190003
5479000b 004a582b 15600008 0018c027 000f7827 03114021 0118c02b 01ec7821
030f2821 01c04821 01a01021 004a582b 15600007 24030001 55420005 00001821
0130802b 16000003 306300ff 00001821 306300ff 1060003a 00ac182b 14600007
24020001 55850005 00001021 0111882b 16200003 304200ff 00001021 304200ff
1040002f 00c73025 10c00015 00001021 14a00008 00001821 14a00004 24050001
2d050020 10a00004 24050001 10000003 01051004 24050001 01051804 000928c0
00852021 8c850000 00a22825 ac850000 8c850004 00a32825 10000016 ac850004
54a00009 24050001 14a00003 24050001 2d020020 10400005 01052804 00051027
10000004 2403ffff 01052804 00051827 2402ffff 000928c0 00852021 8c850000
00a22824 ac850000 8c850004 00a32824 ac850004 01202021 10000003 01002821
00002021 00002821 00801021 00a01821 8fb10004 8fb00000 03e00008 27bd0008
'drawline
27bdffa0 afbf005c afbe0058 afb70054 afb60050 afb5004c afb40048 afb30044
afb20040 afb1003c afb00038 0080a821 afa60068 afa7006c 8fa20070 8fa30078
8fa40080 8fa50088 00408021 00609021 00809821 0065a02a 00a33023 00653823
00f4300a 00c0a021 0044402a 00823823 00443023 00e8300b 00d4a02a 12800005
00a0b021 00a09821 0080b021 00608021 00409021 0270102a 10400008 0256102a
02401021 02c09021 0040b021 02001021 02608021 00409821 0256102a 10400007
0270b823 02d2b023 00178fc2 02378821 00118843 10000006 241e0001 0256b023
00178fc2 02378821 00118843 241effff 0270102a 1440003a 8fbf005c 5280001a
afb00010 afb20010 001217c3 afa20014 afb00018 001017c3 afa2001c 8fa20090
8fa30094 afa20020 afa30024 8fa60098 8fa7009c afa60028 afa7002c 8fa200a0
8fa300a4 afa20030 afa30034 02a02021 8fa60068 8fa7006c 0411FF1D 00000000
10000018 02368823 001017c3 afa20014 afb20018 001217c3 afa2001c 8fa60090
8fa70094 afa60020 afa70024 8fa20098 8fa3009c afa20028 afa3002c 8fa600a0
8fa700a4 afa60030 afa70034 02a02021 8fa60068 8fa7006c 0411FF05 00000000
02368823 06210003 26100001 025e9021 02378821 0270102a 1040ffc8 8fbf005c
8fbe0058 8fb70054 8fb60050 8fb5004c 8fb40048 8fb30044 8fb20040 8fb1003c
8fb00038 03e00008 27bd0060
'drawchar
27bdff40 afbf00bc afbe00b8 afb700b4 afb600b0
afb500ac afb400a8 afb300a4 afb200a0 afb1009c afb00098 afa400c0 8fa200d0
afa20068 8fa300d4 afa30070 8fa400d8 afa40074 8fa500dc afa50078 8fb000e0
8fb400e4 8fa200e8 afa20080 8fa300ec afa30088 afa60048 00431025 144000b7
afa7004c 8fa50068 24a20005 0045182b afa2005c 8fa60070 00661821 afa30064
27b50048 24020005 afa20060 0200b021 0280b821 0200f021 10000093 afb4006c
92a20000 02021007 30420001 1040003b 24030001 17c3001d 8fa30054 8fa4006c
5480001b afa30010 8fa5005c afa50010 8fa60064 afa60014 afb20018 afb4001c
8fa200f0 8fa300f4 afa20020 afa30024 8fa400f8 8fa500fc afa40028 afa5002c
8fa20100 8fa30104 afa20030 afa30034 8fa400c0 24060001 00003821 0411FEA4
00000000 10000056 26100001 afa30010 8fa40058 afa40014 afb10018 afb3001c
afb60020 afb70024 afb60028 afb7002c 8fa200f0 8fa300f4 afa20030 afa30034
8fa400f8 8fa500fc afa40038 afa5003c 8fa20100 8fa30104 afa20040 afa30044
8fa400c0 24060001 00003821 0411FC64 00000000 1000003a 26100001 17c3001d
8fa30054 8fa4006c 5480001b afa30010 8fa5005c afa50010 8fa60064 afa60014
afb20018 afb4001c 8fa200f0 8fa300f4 afa20020 afa30024 8fa400f8 8fa500fc
afa40028 afa5002c 8fa20100 8fa30104 afa20030 afa30034 8fa400c0 00003021
00003821 0411FE6A 00000000 1000001c 26100001 afa30010 8fa40058 afa40014
afb10018 afb3001c afb60020 afb70024 afb60028 afb7002c 8fa200f0 8fa300f4
afa20030 afa30034 8fa400f8 8fa500fc afa40038 afa5003c 8fa20100 8fa30104
afa20040 afa30044 8fa400c0 00003021 00003821 0411FC2A 00000000 26100001
02361021 0051182b 02779821 00408821 00739821 26420001 0052182b 0074a021
24030008 1603ff7e 00409021 8fa40060 2484ffff afa40060 8fa5005c 24a2ffff
0045202b 8fa60064 24c3ffff afa2005c 00831821 afa30064 8fa20060 2403ffff
104300f6 26b50001 8fa40060 009e0019 00001012 00001810 8fa5006c 70a43002
00c31821 8fa50068 00452021 0082282b 8fa60070 00661021 afa40054 00a21021
afa20058 8fb20074 8fb40078 02408821 02809821 1000ff5a 00008021 24020001
8fa30080 146200e1 24020002 8fa40088 148000de 00142023 00101023 0002182b
afa2008c 00832023 afa40090 8fa50068 24a20001 0045202b 8fa60070 00862021
00501823 0043102b 00942023 afa3006c 00822023 afa4007c afa50060 afa60064
27b6004d 27a20047 afa20050 8fa30074 2463fff9 afa30084 8fa40074 24820001
0044182b 8fa50078 00651821 0050a823 0055102b 00741823 00621823 afa3005c
8fbe00c0 100000a7 02009021 92c20000 02021007 30420001 10400044 00000000
1657001c 8fa50054 5680001b afa50010 8fa60060 afa60010 8fa20064 afa20014
afb10018 afb3001c 8fa400f0 8fa500f4 afa40020 afa50024 8fa200f8 8fa300fc
afa20028 afa3002c 8fa40100 8fa50104 afa40030 afa50034 03c02021 24060001
00003821 0411FDD2 00000000 10000069 2610ffff afa50010 8fa60058 afa60014
02120019 00001012 00001810 72902002 00831821 02a22023 02a4282b 8fa6005c
00c31023 00452823 afa40018 afa5001c afb20020 afb40024 afb20028 afb4002c
8fa200f0 8fa300f4 afa20030 afa30034 8fa400f8 8fa500fc afa40038 afa5003c
8fa20100 8fa30104 afa20040 afa30044 03c02021 24060001 00003821 0411FB88
00000000 10000043 2610ffff 1657001c 8fa30054 5680001b afa30010 8fa30060
afa30010 8fa40064 afa40014 afb10018 afb3001c 8fa200f0 8fa300f4 afa20020
afa30024 8fa400f8 8fa500fc afa40028 afa5002c 8fa20100 8fa30104 afa20030
afa30034 03c02021 00003021 00003821 0411FD8F 00000000 10000026 2610ffff
afa30010 8fa40058 afa40014 02120019 00001012 00001810 72902002 00831821
02a22023 02a4282b 8fa6005c 00c31023 00452823 afa40018 afa5001c afb20020
afb40024 afb20028 afb4002c 8fa200f0 8fa300f4 afa20030 afa30034 8fa400f8
8fa500fc afa40038 afa5003c 8fa20100 8fa30104 afa20040 afa30044 03c02021
00003021 00003821 0411FB45 00000000 2610ffff 26220001 0051182b 00408821
2402ffff 1602ff71 00739821 8fa3006c 8fa4008c 00641021 0043182b 8fa5007c
8fa60090 00a62021 afa2006c 00642021 afa4007c 8fa30060 2462ffff 0043182b
8fa50064 24a4ffff afa20060 00642021 afa40064 26d6ffff 8fa60050 52c600d9
02408021 8fa2006c afa20054 8fa3007c afa30058 8fa40084 8fa50074 0085982b
8fa60078 24c2ffff 00808821 02629821 24100007 1000ff4d 24170001 03c08021
8fb4006c 24020002 8fa30080 146200c6 24020003 8fa40088 148000c4 8fa30080
00101023 0002182b 00142023 afa2007c 00832023 afa40080 8fa50068 24a20001
0045202b 8fa60070 00862021 00501823 0043102b 00942023 afa30060 00822023
afa40064 afa0005c 0200b021 0280b821 27a20047 afa20050 0200f021 1000009c
afb4006c 92020000 02a21024 1040003b 24030001 17c3001d 8fa30054 8fa4006c
5480001b afa30010 8fa50068 afa50010 8fa60070 afa60014 afb20018 afb4001c
8fa20100 8fa30104 afa20030 afa30034 8fa400c0 24060001 00003821 0411FCFC
00000000 10000056 2610ffff afa30010 8fa40058 afa40014 afb10018 afb3001c
8fa400c0 24060001 00003821 0411FABC 00000000 1000003a 2610ffff 17c3001d
8fa30054 8fa4006c 5480001b afa30010 8fa50068 afa50010 8fa60070 afa60014
00003821 0411FCC2 00000000 1000001c 2610ffff afa30010 8fa40058 afa40014
afa20040 afa30044 8fa400c0 00003021 00003821 0411FA82 00000000 2610ffff
8fa30050 1603ff7f 00409021 8fa4005c 24840001 afa4005c 8fa50060 8fa6007c
00a61021 0045202b 8fa50064 8fa60080 00a61821 afa20060 00831821 afa30064
8fa30068 2462ffff 0043202b 8fa50070 24a3ffff afa20068 00831821 afa30070
8fa6005c 24020008 10c20104 8fa20048 24030001 8fa4005c 0083a804 8fa50060
afa50054 8fa60064 afa60058 27b0004d 8fb20074 8fb40078 02408821 1000ff59
02809821 24020003 8fa30080 146200f2 8fa40088 148000f0 00101023 0002182b
00142023 afa20084 00832023 afa40088 00101742 001418c0 00431825 001020c0
00901023 0082202b 00741823 00641823 8fa50068 00452021 0082102b 8fa60070
00661821 afa40064 00431821 afa3006c 24a20007 0045182b afa2005c 00661821
afa30070 24020007 afa20060 8fa30074 24620001 0043282b 8fa40078 00a42821
00101823 0003202b 00143023 00c42023 00033782 00042080 00c43025 00032080
00901821 0064202b 00d43021 00862021 000337c2 00042040 00c42025 00031840
00431821 afa3007c 0062102b 00a41821 00431821 afa3008c 8fa50074 24a5fffb
afa50080 8fa60074 00a6182b 8fa40078 2482ffff 00621021 afa20074 0280b021
1000009c 0200a021 92020000 02e21024 1040003b 24030001 24050001 1685001c
8fa50058 56c0001b afa50010 8fa6005c afa60010 8fa20070 afa20014 afb20018
afb5001c 8fa400f0 8fa500f4 afa40020 afa50024 8fa200f8 8fa300fc afa20028
afa3002c 8fa40100 8fa50104 afa40030 afa50034 8fa400c0 24060001 00003821
0411FC0B 00000000 10000055 26100001 afa50010 8fa60068 afa60014 afb10018
afb3001c afb40020 afb60024 afb40028 afb6002c 8fa200f0 8fa300f4 afa20030
afa30034 8fa400f8 8fa500fc afa40038 afa5003c 8fa20100 8fa30104 afa20040
afa30044 8fa400c0 24060001 00003821 0411F9CB 00000000 10000039 26100001
1683001c 8fa30058 56c0001b afa30010 8fa4005c afa40010 8fa50070 afa50014
afb20018 afb5001c 8fa200f0 8fa300f4 afa20020 afa30024 8fa400f8 8fa500fc
00003821 0411FBD2 00000000 1000001c 26100001 afa30010 8fa40068 afa40014
afb10018 afb3001c afb40020 afb60024 afb40028 afb6002c 8fa200f0 8fa300f4
afa20040 afa30044 8fa400c0 00003021 00003821 0411F992 00000000 26100001
023e1021 0051182b 8fa40054 02649821 00408821 00739821 26420001 0052182b
00409021 8fa50050 1605ff7f 0075a821 8fa60060 24c6ffff afa60060 8fa30064
8fa40084 00641021 0043202b 8fa5006c 8fa60088 00a61821 afa20064 00831821
afa3006c 8fa3005c 2462ffff 0043202b 8fa50070 24a3ffff afa2005c 00831821
afa30070 2402ffff 8fa60060 10c20013 8fa20048 24170001 8fa20060 0057b804
8fa30064 afa30058 8fa4006c afa40068 27b00048 0280f021 afb60054 8fb1007c
8fb3008c 8fb20080 8fb50074 27a5004e 1000ff55 afa50050 8fa20048 8fa3004c
8fbf00bc 8fbe00b8 8fb700b4 8fb600b0 8fb500ac 8fb400a8 8fb300a4 8fb200a0
8fb1009c 8fb00098 03e00008 27bd00c0
'main
27bdffb0 afbf004c 00e06021 8fab0060
8faa0064 8fa90068 8fa8006c 8fae0070 8c820000 8c830004 00432025 1480001d
8fad0074 8cc20000 8ce30000 afa30010 00031fc3 afa30014 8d630000 afa30018
00031fc3 afa3001c 8d430000 afa30020 00031fc3 afa30024 8d230000 afa30028
00031fc3 afa3002c 8d030000 afa30030 00031fc3 afa30034 00a02021 00403021
00023fc3 0411FB4A 00000000 10000076 8fbf004c 24040001 14440027 24040002
14600025 00000000 8cc20000 8ce30000 afa30010 00031fc3 afa30014 8d630000
afa30018 00031fc3 afa3001c 8d430000 afa30020 00031fc3 afa30024 8d230000
afa30028 00031fc3 afa3002c 8d030000 afa30030 00031fc3 afa30034 8dc30000
afa30038 00031fc3 afa3003c 8da30000 afa30040 00031fc3 afa30044 00a02021
00403021 00023fc3 0411F8FD 00000000 1000004d 8fbf004c 14440026 24040003
14600024 00000000 8cc70004 8cc60000 8d820000 afa20010 000217c3 afa20014
8d620000 afa20018 000217c3 afa2001c 8d420000 afa20020 000217c3 afa20024
8d220000 afa20028 000217c3 afa2002c 8d020000 afa20030 000217c3 afa20034
8dc20000 afa20038 000217c3 afa2003c 8da20000 afa20040 000217c3 afa20044
00a02021 0411FC09 00000000 10000026 8fbf004c 14440024 8fbf004c 14600022
00a02021 8cc70004 8cc60000 8d820000 afa20010 000217c3 afa20014 8d620000
afa20018 000217c3 afa2001c 8d420000 afa20020 000217c3 afa20024 8d220000
afa20028 000217c3 afa2002c 8d020000 afa20030 000217c3 afa20034 8dc20000
afa20038 000217c3 afa2003c 8da20000 afa20040 000217c3 afa20044 0411FB60
00000000 8fbf004c 03e00008 27bd0050
End CFunction
CFunction font
00000000
00000000 00000000 4f5b3e00 00003e5b 4f6b3e00 00003e6b 7c3e1c00 00001c3e
7e3c1800 0000183c 7d571c00 00001c57 7f5e1c00 00001c5e 3c180000 00000018
c3e7ff00 0000ffe7 24180000 00000018 dbe7ff00 0000ffe7 3a060e00 00003048
79292600 00002629 05050700 0000407f 05253f00 0000407f e73c5a00 00005a3c
1c1c0800 00007f3e 1c3e7f00 0000081c 7f221400 00001422 005f5f00 00005f5f
7f017f00 00000609 89956a00 00000066 60606000 00006060 ffa29400 000094a2
7e040800 00000804 7e201000 00001020 2a1c0800 00000808 2a080800 0000081c
10101000 00001e10 0c1e0c00 00000c1e 3e383000 00003038 3e0e0600 0000060e
00000000 00000000 5f000000 00000000 00070000 00000007 147f1400 0000147f
7f2a1200 0000242a 08646200 00002313 56205000 00003649 07030000 00000008
22410000 0000001c 221c0000 00000041 7f1c2a00 00002a1c 3e080800 00000808
70300000 00000080 08080800 00000808 60600000 00000000 08040200 00002010
49453e00 00003e51 7f400000 00000042 49494600 00007249 494d3300 00002141
127f1000 00001814 45453900 00002745 49493100 00003c4a 11090700 00004121
49493600 00003649 49291e00 00004649 14000000 00000000 34000000 00000040
14224100 00000008 14141400 00001414 22140800 00000041 59090600 00000201
5d594e00 00003e41 11127c00 00007c12 49493600 00007f49 41412200 00003e41
41413e00 00007f41 49494100 00007f49 09090100 00007f09 41517300 00003e41
08087f00 00007f08 7f410000 00000041 413f0100 00002040 14224100 00007f08
40404000 00007f40 1c027f00 00007f02 08107f00 00007f04 41413e00 00003e41
09090600 00007f09 51215e00 00003e41 19294600 00007f09 49493200 00002649
7f010300 00000301 40403f00 00003f40 40201f00 00001f20 38403f00 00003f40
08146300 00006314 78040300 00000304 494d4300 00006159 41414100 0000007f
08102000 00000204 41417f00 00000041 01020400 00000402 40404000 00004040
07080000 00000003 54784000 00002054 44443800 00007f28 44442800 00003844
44287f00 00003844 54541800 00003854 7e090200 00000008 a49c7800 000018a4
04047800 00007f08 7d400000 00000044 403d0000 00002040 28440000 00007f10
7f400000 00000041 78047800 00007c04 04047800 00007c08 44443800 00003844
24241800 0000fc18 2418fc00 00001824 04040800 00007c08 54542400 00004854
3f442400 00000404 40207c00 00003c40 40201c00 00001c20 30403c00 00003c40
10284400 00004428 90907c00 00004c90 544c4400 00004464 36410000 00000008
77000000 00000000 36080000 00000041 02040200 00000201 23263c00 00003c26
a1611200 00001ea1 40207a00 00003a40 54555900 00003854 55794100 00002155
54784200 00002254 54784000 00002155 55794000 00002054 52721200 00000c1e
55555900 00003955 54545900 00003954 54545800 00003955 457c4100 00000000
457d4200 00000002 457c4000 00000001 11127d00 00007d12 2528f000 0000f028
55450000 00007c54 547c5400 00002054 097f4900 00007c0a 49493200 00003249
44443a00 00003a44 48483000 0000324a 41217a00 00003a41 40207800 00003a42
a0a07d00 0000009d 42423d00 00003d42 40403d00 00003d40 ff242400 00003c24
49436600 0000487e fc2f2b00 00002b2f 29f62000 0000ff09 7e090300 0000c088
54794100 00002054 447d4100 00000000 484a3200 00003048 40227a00 00003840
0a0a7200 0000007a 19317d00 00007d0d 292f2800 00002629 29292600 00002629
4d402000 00003048 08080800 00003808 08083800 00000808 c8acba00 00002f10
2834fa00 00002f10 7b000000 00000000 2a142200 00000814 2a140800 00002214
5500aa00 0000aa00 aa55aa00 0000aa55 00ff0000 00000000 10ff0000 00001010
14ff0000 00001414 ff00ff00 00001010 f010f000 00001010 14fc0000 00001414
f700ff00 00001414 ff00ff00 00000000 f404fc00 00001414 17101f00 00001414
1f101f00 00001010 141f0000 00001414 10f00000 00001010 001f1000 00000000
101f1000 00001010 10f01000 00001010 00ff1000 00000000 10101000 00001010
10ff1000 00001010 00ff1400 00000000 ff00ff00 00000000 1f101700 00000000
fc04f400 00000000 17101700 00001414 f404f400 00001414 ff00f700 00000000
14141400 00001414 f700f700 00001414 14171400 00001414 1f101f00 00001010
14f41400 00001414 f010f000 00001010 1f101f00 00000000 001f1400 00000000
00fc1400 00000000 f010f000 00000000 ff10ff00 00001010 14ff1400 00001414
101f0000 00001010 00f01000 00000000 ffffff00 0000ffff f0f0f000 0000f0f0
ff000000 0000ffff 00ffff00 00000000 0f0f0f00 00000f0f 44384400 00003844
4a4a3400 0000fc4a 02060600 00007e02 027e0200 0000027e 49416300 00006355
443c0400 00003844 201e2000 0000407e 7e020200 00000602 e7a59900 000099a5
492a1c00 00001c2a 01724c00 00004c72 4d4d3000 0000304a 78483000 00003048
5a463d00 0000bc62 49490000 00003e49 01017e00 00007e01 2a2a2a00 00002a2a
5f444400 00004444 4a444000 00004051 4a514000 00004044 ff010300 00000000
ff000000 0000e080 6b6b0800 00000808 36243600 00003612 090f0600 0000060f
18180000 00000000 10100000 00000000 ff010100 00003040 01011e00 0000001f
1d171200 00000019 3c3c3c00 0000003c 00000000 00000000
End CFunction
long long Ngetnextupdate(unsigned char outchar[],unsigned int *startcol, unsigned int *startrow,unsigned int *maxcols,unsigned int *maxrows, unsigned long long screen[], unsigned long long displayed[]){
union utype{
unsigned long long b;
unsigned char a[8];
}in,out;
signed long i,j,first[8],last[8],count,myreturn;
count=0;
for(i=0;i<*maxrows;i++){
first=-1;
last=-1;
for (i=0;i<*maxcols;i++){
in.b=screen;
out.b=displayed;
for(j=0;j<*maxrows;j++){
if(in.a[j]!=out.a[j]){
if(first[j]==-1){
first[j]=i;
last[j]=i;
else last[j]=i;
myreturn=-1;
for(i=*maxrows-1;i>=0;i--){
if(first!=-1)myreturn=i; //find the first row with data
if(myreturn==-1)return 0;
*startcol=first[myreturn];
for (i=first[myreturn];i<=last[myreturn];i++){
in.b=screen;
out.b=displayed;
count++;
out.a[myreturn]=in.a[myreturn];
outchar[count]=out.a[myreturn];
displayed=out.b;
*startrow=myreturn;
outchar[0]=count;
return count;
Zonker
Posted: 09:11am 07 Dec 2014
Awesome work Matherp..!
U da man when it comes to getin the code...! Makes me wonder if a new board, (possible IR remote transceiver) shouldn't be spun up using the Nokia unit...
I think I have one of these... I will give a go at testing out your work...
Thanks big M..!
Posted: 10:42am 07 Dec 2014
  matherp said   My wish list for the Micromite Mk2 is now pretty much empty. Huge thanks and congratulations should go to Geoff for what he has achieved with the new Micromite. Personally, my projects will now all be either Micromite-based or 8-pin PIC or PICAXE. I can't see any reason to use anything else
Peter
You forgot the Maximite.
My home DAQ system currently runs a Maximite and a few 08M PICAXE's.
Soon to include a distributed system of micromites. Thanks to your work, I might replace the 2x16 LCD's with Nokia displays. (They are on the slow boat from China)
Edited by TassyJim 2014-12-08
BobD
Posted: 11:20am 07 Dec 2014
Peter
could you attach your programs as a ZIP file. This board inserts the occasional blank just to make our lives miserable. I have found one and there may be others.
[code]dim as string year$,month$,day$,hour$,min$,sec$,tempstr$,degrees$,fraction s$ [/code]
There may be an extra blank after the word string and it may not matter but the blank in fractions$ is important.
Edited by BobD 2014-12-08
Posted: 12:24pm 07 Dec 2014
You can reduce the instances of extra spaces by keeping the "word" length down.
The example line can be safely written as
dim as string year$, month$, day$, hour$, min$, sec$, tempstr$, degrees$, fractions$
I know all the extra spaces take up valuable memory in the micromite and a ZIP is the best way of getting the code in without any gremlins.
Zonker
Posted: 04:21pm 14 Dec 2014
Probably a silly question...
I wanted to use different pins for the interface. I assume you would just change the pin numbers here..?
const N_RST=24
const N_CE=23
const N_DC=15
const N_Datain=3
const N_CLK=25
const N_VCC=7
Just thought I would check before wiring things up...
Posted: 10:37pm 14 Dec 2014
Yes on this display the pins are fully flexible - except of course the SPI pins.
Gordz
Posted: 10:27am 17 Dec 2014
These little 'Nokia' PCD8544 based displays are great and if you don't use the backlight they draw next to nothing. I have been using a little interface board with them so that I can drive them with only one data line (or power it with an I/O pin) and they are worth their weight in gold for de-bugging. The I/F board only has a basic character font but it takes the grunt work away from your system by having the font, backlight control, contrast, number display, graph and graphics all on board.
Gordz
Posted: 05:45pm 12 Jan 2015
Yeh I know that its a little late but here is a link to the little I/F board in action. Very little overhead on the host as it just needs a simple 9 bit serial function.
https://www.youtube.com/watch?v=rO45ZlcvwtU
paceman
Posted: 07:19pm 12 Jan 2015
How about a bit more explanation of what you're doing here Gordon - and even a photo of the board? The idea of being able to use the 5110's with one data line is certainly appealing. I take it the I/F board is a another micro that you've programmed - is it a Micromite for example?
Greg
