Local Time 10:02 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FTP
palcal
Posted: 08:29pm 10 Nov 2014
A bit of a change of topic.
I have a WEB server that I built some years ago and never really used, however I am now designing a page for a small club I belong to. I have a folder containing a number of files on my computer, when I use the FTP in windows I can log in OK. If I type
"put index.html" the file transfers but that is the only file that will. When I try any other file in the same folder I get a response of 'file not found'
Any answers I've searched everywhere.
Paul.
Posted: 08:42pm 10 Nov 2014
Need some more info Paul.
Are you FTPing to a Windows or Linux or Other server? Linux servers can be a pain, they are case sensitive. You can have both index.html and Index.html in the same folder, and the ftp client gets confused.
Speaking of ftp client, what about using a full blown ftp client like FileZilla? Makes the whole process much easier.
Posted: 08:50pm 10 Nov 2014
Even better, get Total Commander.
http://www.ghisler.com/
I wouldn't be without it.
palcal
Posted: 10:27pm 10 Nov 2014
I built the WIB from Silicon Chip, so it is connected to my router. I can undo the case and take out the memory card and upload files that way, but it is easier to use FTP.
Tried FileZilla and had problems will try Total Commander.
Paul.
jimbotron
Posted: 03:56am 11 Nov 2014
Some silly things to check. When you run ftp, have you made sure that you are in the directory that you want to send files from? Have you tried using the full path name of the file you are trying to send? When you run !dir can you see the files you want to send. !dir issues the dir command to your local directory.
Do you have spaces in your file names?
Jimmy
donmck
Posted: 10:22am 11 Nov 2014
  TassyJim said   Even better, get Total Commander.
I couldn't be without it
Cheers Don...
https://www.dontronics.com
palcal
Posted: 11:20am 11 Nov 2014
Thanks Jimbo when I use the full path name it works OK'.
THANKS ALL.
Paul.
