Local Time 14:25 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : real Bug in Mk 2 vers.20
plasma
Posted: 01:37pm 08 Nov 2014
beware !
Please dont try this at Home ! yes really !!!
dim a(5000)
sub(a)
end
after typing this you have no access to editor or code ! all is gone.
the editor spits error invalid function name and you loose.
i run into this after a typo in my led routine.
first time i cant believe its true , so i flashed version 20. but its the same
Posted: 04:35pm 08 Nov 2014
I can confirm the problem.
The only way to recover is to power up with Tx and Rx shorted.
[2] Sub(a)
Error: Invalid function name
> list
[2] Sub(a)
> new
[2] Sub(a)
micromite 4.6b20
Posted: 06:53pm 08 Nov 2014
I also can confirm this - same results as Jim, and needed to do the same to recover. Version 4.6 Beta 20
A nice sharp thorny bug, that one!
Posted: 06:25am 09 Nov 2014
  Grogster said  A nice sharp thorny bug, that one!
Yes, it is.
Thanks plasma, I will fix it in the next beta.
