Local Time 09:39 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : COM 1 Problem
edu001
Posted: 09:45am 31 Oct 2014
Hi
I am trying to open COM1 with 1 stop bit like this: OPEN "COM1:9600, S1 AS #1
I get Error: Not enough memory
Where as OPEN "COM1:9600, S2 AS #1 works ok
Any Ideas
Posted: 10:04am 31 Oct 2014
Missing quote
hitsware
Posted: 10:08am 31 Oct 2014
Assuming you have a MicroMite......:See page 53 ......
edu001
Posted: 10:16am 31 Oct 2014
  JohnS said   Missing quote
You are correct
edu001
Posted: 10:19am 31 Oct 2014
Just miss typed OPEN "COM1:9600, S1" AS #1
I really need to fix this
The protocol I need to follow is 1+8+1 no parity
Is the start bit the rising edge and the stop bit the falling edge or do I need to define it ?
edu001
Posted: 10:31am 31 Oct 2014
  hitsware said   Assuming you have a MicroMite......:See page 53 ......
Thanks for the link :) but I have been through the manual and there is no mention of using start bits or S1 as a single stop bit
Posted: 10:35am 31 Oct 2014
Bearing in mind the manual states the defaults I'm not sure why you're using what you have.
edu001
Posted: 10:59am 31 Oct 2014
  JohnS said   Bearing in mind the manual states the defaults I'm not sure why you're using what you have.
I was discussing it with WW and could not ascertain if 1 stop bit was the default value and 2 stop bits was an option or do both have to be defined ?
Posted: 11:13am 31 Oct 2014
One stop bit is the default setting.
If you want one stop bit just leave the S2 out altogether.
The other thing that catches people out is the polarity.
Maximites generally use TTL which has the resting level at +V and a start bit will go to zero.
RS232 has a resting level of -V and a start bit will go to +V
You might need to INVert the signal.
