Local Time 14:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : General purpose 8 port I/O chip
Posted: 12:54pm 30 Oct 2014
I have come across this new chip which could be quiet useful:
http://www.analog.com/static/imported-files/data_sheets/AD55 93R.pdf
It is an eight port I/O chip with an I2C interface. What is outstanding is that any pin can be independently configured as an:
- Analog output (ie, DAC)
- Analog input (ie, ADC)
- Digital input (with optional pulldown)
- Digital output (normal or open collector)
The DAC and ADC are 12 bit and it includes a 0.5% accurate voltage reference. It makes a great general purpose I/O chip.
I have asked for some samples - now to think up an interesting application...
Posted: 01:46pm 30 Oct 2014
How much?
JohnL
Posted: 01:56pm 30 Oct 2014
More than US$7each for qty 10 from Digkey. No thanks.
If speed is not an issue, better option is to configure a ucontroller as universal I/O device. Many low end ucontrollers don't have DACs.
Edited by JohnL 2014-10-31
Posted: 02:14pm 30 Oct 2014
I have successfully used a 2nd(or 3rd!) MicoMite IC on I2C to act as port expansion. My model elevator project uses three MM chips. One is a CPU(the master), one is an input controller(slave #1), and the third one is an output controller(slave #2).
A triple-core MicroMite.
There was also a MCP serial port-expansion chip that talked on I2C - I forget the part number.
Zonker
Posted: 03:44pm 30 Oct 2014
Wow..!
Great find Geoff.. In one chip, you could design several different kinds of interface boards with 12bit analog and digital control... awesome I can think of a few uses right off... Will have a read of this one...
Thanks.!
Posted: 04:39pm 30 Oct 2014
12 bit DAC and ADC in one package is very useful.
jman
Posted: 07:35pm 30 Oct 2014
That's a great I2C device I have ordered some samples I post the results here
when they arrive
Jman
