Forum Index : Microcontroller and PC projects : nRF24L01
| cwilt Senior Member Joined: 20/03/2012 Location: United StatesPosts: 147 |
There has been some talk about using nordic transceivers with micromites etc. I thought I might fan the flames a little.
My setup is a UBW32 loaded with mmbasic 4.4 with this nordic breakout board from sparkfun. My transmitter is this key FOB from sparkfun . Below is the code I am using to read those key presses from the FOB. Not pretty code but it works. I can confirm that the receive functions work, but I have not yet test the transmit functions. sub NRF.init NRF_CONFIG_RG=0 NRF_ENAA_RG=1 NRF_ENRXADDR_RG=2 NRF_SETUPAW_RG=3 NRF_SETUPRETR_RG=4 NRF_RFCH_RG=5 NRF_RFSETUP_RG=6 NRF_STATUS_RG=7 NRF_OBSERVETX_RG=8 NRF_CD_RG=9 NRF_RXADDRP0_RG=10 NRF_RXADDRP1_RG=11 NRF_RXADDRP2_RG=12 NRF_RXADDRP3_RG=13 NRF_RXADDRP4_RG=14 NRF_RXADDRP5_RG=15 NRF_TXADDR_RG=16 NRF_RXPWP0_RG=17 NRF_RXPWP1_RG=18 NRF_RXPWP2_RG=19 NRF_RXPWP3_RG=20 NRF_RXPWP4_RG=21 NRF_RXPWP5_RG=22 NRF_FIFOSTATUS_RG=23 NRF_MISO=11 NRF_MOSI=12 NRF_CLK=13 NRF_CS=14 NRF_CE=10 NRF_IRQ=9 NRF_ADDRESS_WIDTH=5 NRF_PAYLOAD_WIDTH=4 dim NRF_ADDRESS(NRF_ADDRESS_WIDTH) dim NRF.RX(NRF_PAYLOAD_WIDTH) dim NRF.TX(NRF_PAYLOAD_WIDTH) setpin NRF_MISO,2 setpin NRF_MOSI,8 pin(NRF_CLK)=0:setpin NRF_CLK,8 pin(NRF_CS)=1:setpin NRF_CS,8 pin(NRF_CE)=0:setpin NRF_CE,8 end sub sub NRF.setTXaddr pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_TX_ADDR_RG+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub NRF.setRXaddr(P) pipe=&H0A+P pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,pipe+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub test nrf.readpayload print "Button #";keyfobkey() NRF.clearRXDR end sub function NRF.status() temp=nrf.readreg(NRF_STATUS_RG) NRF.status=temp x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(right$(x$,1)) NRF_RX_P_NO=val("&B"+"mid$(x$,5,3)) NRF_MAX_RT=val(mid$(x$,4,1)) NRF_TX_DS=val(mid$(x$,3,1)) NRF_RX_DR=val(mid$(x$,2,1)) temp=nrf.readreg(NRF_FIFO_STATUS_REG) x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(mid$(x$,3,1)) NRF_TX_EMPTY=val(mid$(x$,4,1)) NRF_RX_FULL=val(mid$(x$,7,1)) NRF_RX_EMPTY=val(mid$(x$,8,1)) end function sub NRF.readpayload local junk NRF.TXMODE do pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h61,H,0,8) for I=1 to NRF_PAYLOAD_WIDTH NRF.RX(I)=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) next I pin(NRF_CS)=1 loop until nrf.readreg(23)=17 NRF.RXMODE pause 200 end sub sub NRF.sendpayload NRF.TXMODE local junk pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&hA0,H,0,8) for I= 1 to NRF_PAYLOAD_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF.TX(I),H,0,8) next I pin(NRF_CS)=1 nrf.rxmode pause 10 nrf.txmode end sub sub NRF.clearRXDR nrf.writereg(NRF_STATUS_RG,64) end sub function NRF.readreg(reg) local junk, byte1 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg,H,0,8) byte1=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) pin(NRF_CS)=1 NRF.readreg=byte1 end function sub NRF.flushRX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE2,H,0,8) pin(NRF_CS)=1 end sub sub NRF.flushTX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE1,H,0,8) pin(NRF_CS)=1 end sub sub NRF.writereg(reg, byte) pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg+32,H,0,8) junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,byte,H,0,8) pin(NRF_CS)=1 end sub sub NRF.RXMODE pin(NRF_CE)=1 end sub sub NRF.TXMODE pin(NRF_CE)=0 end sub function NRF.RX.avail() NRF.RX.avail=0 x= NRF.readreg(NRF_FIFOSTATUS_RG) if x=16 or x=18 then NRF.RX.avail=1 end function sub NRF.keyfobRX.setup pin(NRF_CE)=0 nrf.writereg(NRF_ENAA_RG,0) nrf.writereg(NRF_ENRXADDR_RG,1) nrf.writereg(NRF_RFCH_RG,2) nrf.writereg(NRF_RXPWP0_RG,4) nrf.writereg(NRF_RFSETUP_RG,7) nrf.writereg(NRF_CONFIG_RG,&B00001011) pin(NRF_CE)=1 end sub function keyfobkey() keyfobkey=0 if nrf.rx(1)=30 then keyfobkey=1 pin(0)=1 endif if nrf.rx(1)=23 then keyfobkey=2 pin(0)=0 endif if nrf.rx(1)=29 then keyfobkey=3 if nrf.rx(1)=27 then keyfobkey=4 if nrf.rx(1)=15 then keyfobfey=5 end function sub showRXaddress(x) temprg=&H0A+x pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_RXADDRP0_RG+x,H,0,8) for i=1 to 5 byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) print byte; next i print "" pin(NRF_CS)=1 NRF.readreg=byte1 end sub sub showregs local junk,byte for I=0 to 23 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,I,H,0,8) byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) pin(NRF_CS)=1 print "REG #"+str$(I)+" = "+str$(byte) pause 100 next I end sub 'start NRF.init nrf.clearRXDR nrf.flushrx NRF.keyfobRX.setup setpin NRF_IRQ,7,test NRF.RXMODE do:loop |
| viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925 |
Hi Cwilt, what kind of range are you getting, and what type of antenna do you have on the receiving end? Thanks for the code!!! |
I am using a rubber duck . I have not tested for distance but I have a good sized home and have no issues anywhere inside even at opposite corners and a level between. |
MicroBlocks![]() Guru Joined: 12/05/2012 Location: ThailandPosts: 2209 |
Great code. I like your style using the dot notation to simulate objects/methods/properties. Makes it a lot clearer and closer to newer languages. And it is even interrupt driven. Wonderful. Microblocks. Build with logic. |
I did this about a year ago but my job has kept me away from home for the last 10 months. This was written to be used as a library which is as close as I can get to an object in mmbasic. It would be nice if when a library was loaded that all functions, variables, etc would automatically have the library name appended. For example a library named "NRF.BAS" with a function named "init" once loaded would be called "NRF.init". I have been following the micromite buildup and was waiting for the inclusion of some form of RF module. Geoff recently posted that he was looking for code so I found my files and loaded this onto my test board to confirm that it still worked. Hopefully this helps Geoff. I hear rumors that I could be called back out to work any day now so I am not sure I will have time to build a 2nd setup and create a "Hello World" test between the two. |
Tonight I built another UBW32 and nrf24L01 test board. Loaded mmbasic 4.5 and my code and it did not work. reverted back to 4.4 and it did. My gut says there is a change with interrupt settings. I will figure it out and post new code for 4.5 |
Working 4.5 version. Now I will make a "Hello World" program between 2 maximites using nRF24L01's. 'NRF24L01 basic driver module sub NRF.init NRF_CONFIG_RG=0 NRF_ENAA_RG=1 NRF_ENRXADDR_RG=2 NRF_SETUPAW_RG=3 NRF_SETUPRETR_RG=4 NRF_RFCH_RG=5 NRF_RFSETUP_RG=6 NRF_STATUS_RG=7 NRF_OBSERVETX_RG=8 NRF_CD_RG=9 NRF_RXADDRP0_RG=10 NRF_RXADDRP1_RG=11 NRF_RXADDRP2_RG=12 NRF_RXADDRP3_RG=13 NRF_RXADDRP4_RG=14 NRF_RXADDRP5_RG=15 NRF_TXADDR_RG=16 NRF_RXPWP0_RG=17 NRF_RXPWP1_RG=18 NRF_RXPWP2_RG=19 NRF_RXPWP3_RG=20 NRF_RXPWP4_RG=21 NRF_RXPWP5_RG=22 NRF_FIFOSTATUS_RG=23 NRF_MISO=11 NRF_MOSI=12 NRF_CLK=13 NRF_CS=14 NRF_CE=10 NRF_IRQ=9 NRF_ADDRESS_WIDTH=5 NRF_PAYLOAD_WIDTH=4 dim NRF_ADDRESS(NRF_ADDRESS_WIDTH) dim NRF.RX(NRF_PAYLOAD_WIDTH) dim NRF.TX(NRF_PAYLOAD_WIDTH) setpin NRF_MISO,DIN setpin NRF_MOSI,DOUT pin(NRF_CLK)=0:setpin NRF_CLK,DOUT pin(NRF_CS)=1:setpin NRF_CS,DOUT pin(NRF_CE)=0:setpin NRF_CE,DOUT end sub sub NRF.setTXaddr pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_TX_ADDR_RG+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub NRF.setRXaddr(P) pipe=&H0A+P pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,pipe+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub test nrf.readpayload print "Button #";keyfobkey() NRF.clearRXDR end sub function NRF.status() temp=nrf.readreg(NRF_STATUS_RG) NRF.status=temp x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(right$(x$,1)) NRF_RX_P_NO=val("&B"+"mid$(x$,5,3)) NRF_MAX_RT=val(mid$(x$,4,1)) NRF_TX_DS=val(mid$(x$,3,1)) NRF_RX_DR=val(mid$(x$,2,1)) temp=nrf.readreg(NRF_FIFO_STATUS_REG) x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(mid$(x$,3,1)) NRF_TX_EMPTY=val(mid$(x$,4,1)) NRF_RX_FULL=val(mid$(x$,7,1)) NRF_RX_EMPTY=val(mid$(x$,8,1)) end function sub NRF.readpayload local junk NRF.TXMODE do pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h61,H,0,8) for I=1 to NRF_PAYLOAD_WIDTH NRF.RX(I)=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) next I pin(NRF_CS)=1 loop until nrf.readreg(23)=17 NRF.RXMODE pause 200 end sub sub NRF.sendpayload NRF.TXMODE local junk pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&hA0,H,0,8) for I= 1 to NRF_PAYLOAD_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF.TX(I),H,0,8) next I pin(NRF_CS)=1 nrf.rxmode pause 10 nrf.txmode end sub sub NRF.clearRXDR nrf.writereg(NRF_STATUS_RG,64) end sub function NRF.readreg(reg) local junk, byte1 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg,H,0,8) byte1=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) pin(NRF_CS)=1 NRF.readreg=byte1 end function sub NRF.flushRX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE2,H,0,8) pin(NRF_CS)=1 end sub sub NRF.flushTX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE1,H,0,8) pin(NRF_CS)=1 end sub sub NRF.writereg(reg, byte) pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg+32,H,0,8) junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,byte,H,0,8) pin(NRF_CS)=1 end sub sub NRF.RXMODE pin(NRF_CE)=1 end sub sub NRF.TXMODE pin(NRF_CE)=0 end sub function NRF.RX.avail() NRF.RX.avail=0 x= NRF.readreg(NRF_FIFOSTATUS_RG) if x=16 or x=18 then NRF.RX.avail=1 end function sub NRF.keyfobRX.setup pin(NRF_CE)=0 nrf.writereg(NRF_ENAA_RG,0) nrf.writereg(NRF_ENRXADDR_RG,1) nrf.writereg(NRF_RFCH_RG,2) nrf.writereg(NRF_RXPWP0_RG,4) nrf.writereg(NRF_RFSETUP_RG,7) nrf.writereg(NRF_CONFIG_RG,&B00001011) pin(NRF_CE)=1 end sub function keyfobkey() keyfobkey=0 if nrf.rx(1)=30 then keyfobkey=1 pin(0)=1 endif if nrf.rx(1)=23 then keyfobkey=2 pin(0)=0 endif if nrf.rx(1)=29 then keyfobkey=3 if nrf.rx(1)=27 then keyfobkey=4 if nrf.rx(1)=15 then keyfobfey=5 end function sub showRXaddress(x) temprg=&H0A+x pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_RXADDRP0_RG+x,H,0,8) for i=1 to 5 byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) print byte; next i print "" pin(NRF_CS)=1 NRF.readreg=byte1 end sub sub showregs local junk,byte for I=0 to 23 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,I,H,0,8) byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) pin(NRF_CS)=1 print "REG #"+str$(I)+" = "+str$(byte) pause 100 next I end sub sub testtx NRF.init nrf.clearRXDR nrf.flushRX nrf.keyforRX.setup nrf.tx(1)=72 nrf.tx(2)=69 nrf.tx(3)=76 nrf.tx(4)=80 nrf.sendpayload end sub 'start NRF.init nrf.clearRXDR nrf.flushrx NRF.keyfobRX.setup setpin NRF_IRQ,INTL,test NRF.RXMODE do:loop |
| plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
i cant wait Hurry up! |
I wish there were more hours in a day. |
I had to roll back to version 4.4 due to a bug in 4.5 but I was able to duplicate the transmissions of the key fob with mmbasic code. Receive code 'NRF24L01 basic driver module sub NRF.init NRF_CONFIG_RG=0 NRF_ENAA_RG=1 NRF_ENRXADDR_RG=2 NRF_SETUPAW_RG=3 NRF_SETUPRETR_RG=4 NRF_RFCH_RG=5 NRF_RFSETUP_RG=6 NRF_STATUS_RG=7 NRF_OBSERVETX_RG=8 NRF_CD_RG=9 NRF_RXADDRP0_RG=10 NRF_RXADDRP1_RG=11 NRF_RXADDRP2_RG=12 NRF_RXADDRP3_RG=13 NRF_RXADDRP4_RG=14 NRF_RXADDRP5_RG=15 NRF_TXADDR_RG=16 NRF_RXPWP0_RG=17 NRF_RXPWP1_RG=18 NRF_RXPWP2_RG=19 NRF_RXPWP3_RG=20 NRF_RXPWP4_RG=21 NRF_RXPWP5_RG=22 NRF_FIFOSTATUS_RG=23 NRF_MISO=11 NRF_MOSI=12 NRF_CLK=13 NRF_CS=14 NRF_CE=10 NRF_IRQ=9 NRF_ADDRESS_WIDTH=5 NRF_PAYLOAD_WIDTH=4 dim NRF_ADDRESS(NRF_ADDRESS_WIDTH) dim NRF.RX(NRF_PAYLOAD_WIDTH) dim NRF.TX(NRF_PAYLOAD_WIDTH) setpin NRF_MISO,2 setpin NRF_MOSI,8 pin(NRF_CLK)=0:setpin NRF_CLK,8 pin(NRF_CS)=1:setpin NRF_CS,8 pin(NRF_CE)=0:setpin NRF_CE,8 end sub sub NRF.setTXaddr pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_TX_ADDR_RG+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub NRF.setRXaddr(P) pipe=&H0A+P pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,pipe+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub test nrf.readpayload print "Button #";keyfobkey() NRF.clearRXDR end sub function NRF.status() temp=nrf.readreg(NRF_STATUS_RG) NRF.status=temp x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(right$(x$,1)) NRF_RX_P_NO=val("&B"+"mid$(x$,5,3)) NRF_MAX_RT=val(mid$(x$,4,1)) NRF_TX_DS=val(mid$(x$,3,1)) NRF_RX_DR=val(mid$(x$,2,1)) temp=nrf.readreg(NRF_FIFO_STATUS_REG) x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(mid$(x$,3,1)) NRF_TX_EMPTY=val(mid$(x$,4,1)) NRF_RX_FULL=val(mid$(x$,7,1)) NRF_RX_EMPTY=val(mid$(x$,8,1)) end function sub NRF.readpayload local junk NRF.TXMODE do pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h61,H,0,8) for I=1 to NRF_PAYLOAD_WIDTH NRF.RX(I)=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) next I pin(NRF_CS)=1 loop until nrf.readreg(23)=17 NRF.RXMODE pause 200 end sub sub NRF.sendpayload NRF.TXMODE local junk pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&hA0,H,0,8) for I= 1 to NRF_PAYLOAD_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF.TX(I),H,0,8) next I pin(NRF_CS)=1 nrf.rxmode pause 10 nrf.txmode end sub sub NRF.clearRXDR nrf.writereg(NRF_STATUS_RG,64) end sub function NRF.readreg(reg) local junk, byte1 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg,H,0,8) byte1=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) pin(NRF_CS)=1 NRF.readreg=byte1 end function sub NRF.flushRX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE2,H,0,8) pin(NRF_CS)=1 end sub sub NRF.flushTX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE1,H,0,8) pin(NRF_CS)=1 end sub sub NRF.writereg(reg, byte) pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg+32,H,0,8) junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,byte,H,0,8) pin(NRF_CS)=1 end sub sub NRF.RXMODE pin(NRF_CE)=1 end sub sub NRF.TXMODE pin(NRF_CE)=0 end sub function NRF.RX.avail() NRF.RX.avail=0 x= NRF.readreg(NRF_FIFOSTATUS_RG) if x=16 or x=18 then NRF.RX.avail=1 end function sub NRF.keyfobRX.setup pin(NRF_CE)=0 nrf.writereg(NRF_ENAA_RG,0) nrf.writereg(NRF_ENRXADDR_RG,1) nrf.writereg(NRF_RFCH_RG,2) nrf.writereg(NRF_RXPWP0_RG,4) nrf.writereg(NRF_RFSETUP_RG,7) nrf.writereg(NRF_CONFIG_RG,&B00001011) pin(NRF_CE)=1 end sub sub BLINKLED pin(0)=0 pause 50 pin(0)=1 pause 50 pin(0)=0 pause 50 pin(0)=1 end sub function keyfobkey() keyfobkey=0 if nrf.rx(1)=30 then keyfobkey=1 BLINKLED endif if nrf.rx(1)=23 then keyfobkey=2 BLINKLED endif if nrf.rx(1)=29 then keyfobkey=3 BLINKLED ENDIF if nrf.rx(1)=27 then keyfobkey=4 BLINKLED ENDIF if nrf.rx(1)=15 then keyfobfey=5 BLINKLED ENDIF end function sub showRXaddress(x) temprg=&H0A+x pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_RXADDRP0_RG+x,H,0,8) for i=1 to 5 byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) print byte; next i print "" pin(NRF_CS)=1 NRF.readreg=byte1 end sub sub showregs local junk,byte for I=0 to 23 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,I,H,0,8) byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) pin(NRF_CS)=1 print "REG #"+str$(I)+" = "+str$(byte) pause 100 next I end sub sub testtx NRF.init nrf.clearRXDR nrf.flushRX nrf.keyforRX.setup nrf.tx(1)=72 nrf.tx(2)=69 nrf.tx(3)=76 nrf.tx(4)=80 nrf.sendpayload end sub 'start NRF.init nrf.clearRXDR nrf.flushrx NRF.keyfobRX.setup setpin NRF_IRQ,7,test NRF.RXMODE do:loop |
Transmit code 'NRF24L01 basic driver module sub NRF.init NRF_CONFIG_RG=0 NRF_ENAA_RG=1 NRF_ENRXADDR_RG=2 NRF_SETUPAW_RG=3 NRF_SETUPRETR_RG=4 NRF_RFCH_RG=5 NRF_RFSETUP_RG=6 NRF_STATUS_RG=7 NRF_OBSERVETX_RG=8 NRF_CD_RG=9 NRF_RXADDRP0_RG=10 NRF_RXADDRP1_RG=11 NRF_RXADDRP2_RG=12 NRF_RXADDRP3_RG=13 NRF_RXADDRP4_RG=14 NRF_RXADDRP5_RG=15 NRF_TXADDR_RG=16 NRF_RXPWP0_RG=17 NRF_RXPWP1_RG=18 NRF_RXPWP2_RG=19 NRF_RXPWP3_RG=20 NRF_RXPWP4_RG=21 NRF_RXPWP5_RG=22 NRF_FIFOSTATUS_RG=23 NRF_MISO=11 NRF_MOSI=12 NRF_CLK=13 NRF_CS=14 NRF_CE=10 NRF_IRQ=9 NRF_ADDRESS_WIDTH=5 NRF_PAYLOAD_WIDTH=4 dim NRF_ADDRESS(NRF_ADDRESS_WIDTH) dim NRF.RX(NRF_PAYLOAD_WIDTH) dim NRF.TX(NRF_PAYLOAD_WIDTH) setpin NRF_MISO,2 setpin NRF_MOSI,8 pin(NRF_CLK)=0:setpin NRF_CLK,8 pin(NRF_CS)=1:setpin NRF_CS,8 pin(NRF_CE)=0:setpin NRF_CE,8 end sub sub NRF.setTXaddr pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_TX_ADDR_RG+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub NRF.setRXaddr(P) pipe=&H0A+P pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,pipe+32,H,0,8) for I = 1 to NRF_ADDRESS_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_ADDRESS(I),H,0,8) next I pin(NRF_CS)=1 end sub sub test nrf.readpayload print "Button #";keyfobkey() NRF.clearRXDR end sub function NRF.status() temp=nrf.readreg(NRF_STATUS_RG) NRF.status=temp x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(right$(x$,1)) NRF_RX_P_NO=val("&B"+"mid$(x$,5,3)) NRF_MAX_RT=val(mid$(x$,4,1)) NRF_TX_DS=val(mid$(x$,3,1)) NRF_RX_DR=val(mid$(x$,2,1)) temp=nrf.readreg(NRF_FIFO_STATUS_REG) x$=bin$(temp) do x$="0"+x$ loop until len(x$)=8 NRF_TX_FULL=val(mid$(x$,3,1)) NRF_TX_EMPTY=val(mid$(x$,4,1)) NRF_RX_FULL=val(mid$(x$,7,1)) NRF_RX_EMPTY=val(mid$(x$,8,1)) end function sub NRF.readpayload local junk NRF.TXMODE do pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h61,H,0,8) for I=1 to NRF_PAYLOAD_WIDTH NRF.RX(I)=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) next I pin(NRF_CS)=1 loop until nrf.readreg(23)=17 NRF.RXMODE pause 200 end sub sub NRF.sendpayload 'NRF.TXMODE local junk pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&hA0,H,0,8) for I= 1 to NRF_PAYLOAD_WIDTH junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF.TX(I),H,0,8) next I pin(NRF_CS)=1 nrf.rxmode pause 10 nrf.txmode end sub sub NRF.clearRXDR nrf.writereg(NRF_STATUS_RG,64) end sub function NRF.readreg(reg) local junk, byte1 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg,H,0,8) byte1=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) pin(NRF_CS)=1 NRF.readreg=byte1 end function sub NRF.flushRX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE2,H,0,8) pin(NRF_CS)=1 end sub sub NRF.flushTX pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&HE1,H,0,8) pin(NRF_CS)=1 end sub sub NRF.writereg(reg, byte) pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,reg+32,H,0,8) junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,byte,H,0,8) pin(NRF_CS)=1 end sub sub NRF.RXMODE pin(NRF_CE)=1 end sub sub NRF.TXMODE pin(NRF_CE)=0 end sub function NRF.RX.avail() NRF.RX.avail=0 x= NRF.readreg(NRF_FIFOSTATUS_RG) if x=16 or x=18 then NRF.RX.avail=1 end function sub NRF.keyfobRX.setup pin(NRF_CE)=0 nrf.writereg(NRF_ENAA_RG,0) nrf.writereg(NRF_ENRXADDR_RG,1) nrf.writereg(NRF_RFCH_RG,2) nrf.writereg(NRF_RXPWP0_RG,4) nrf.writereg(NRF_RFSETUP_RG,7) nrf.writereg(NRF_CONFIG_RG,&B00001011) pin(NRF_CE)=1 end sub sub NRF.keyfobTX.setup pin(NRF_CE)=0 nrf.writereg(NRF_ENAA_RG,0) nrf.writereg(NRF_ENRXADDR_RG,1) nrf.writereg(NRF_RFCH_RG,2) nrf.writereg(NRF_RXPWP0_RG,4) nrf.writereg(NRF_RFSETUP_RG,7) nrf.writereg(NRF_CONFIG_RG,&B00001010) pin(NRF_CE)=1 end sub sub BLINKLED pin(0)=0 pause 50 pin(0)=1 pause 50 pin(0)=0 pause 50 pin(0)=1 end sub function keyfobkey() keyfobkey=0 if nrf.rx(1)=30 then keyfobkey=1 BLINKLED endif if nrf.rx(1)=23 then keyfobkey=2 BLINKLED endif if nrf.rx(1)=29 then keyfobkey=3 BLINKLED ENDIF if nrf.rx(1)=27 then keyfobkey=4 BLINKLED ENDIF if nrf.rx(1)=15 then keyfobfey=5 BLINKLED ENDIF end function sub showRXaddress(x) temprg=&H0A+x pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,NRF_RXADDRP0_RG+x,H,0,8) for i=1 to 5 byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&H0,H,0,8) print byte; next i print "" pin(NRF_CS)=1 NRF.readreg=byte1 end sub sub showregs local junk,byte for I=0 to 23 pin(NRF_CS)=0 junk=spi(NRF_MISO,NRF_MOSI,NRF_CLK,I,H,0,8) byte=spi(NRF_MISO,NRF_MOSI,NRF_CLK,&h0,H,0,8) pin(NRF_CS)=1 print "REG #"+str$(I)+" = "+str$(byte) pause 100 next I end sub sub testtx 'NRF.init 'nrf.clearRXDR 'nrf.flushRX 'nrf.keyforRX.setup nrf.tx(1)=30 nrf.tx(2)=0 nrf.tx(3)=0 nrf.tx(4)=0 nrf.sendpayload blinkled pause 1000 nrf.tx(1)=23 nrf.sendpayload blinkled pause 1000 nrf.tx(1)=29 nrf.sendpayload blinkled pause 1000 nrf.tx(1)=27 nrf.sendpayload blinkled pause 1000 nrf.tx(1)=15 nrf.sendpayload blinkled pause 1000 end sub 'start NRF.init nrf.clearRXDR nrf.flushrx NRF.keyfobTX.setup 'setpin NRF_IRQ,7,test 'NRF.RXMODE do testtx loop |
Sorry for all of the posted code. I am at the point now where I must decide on how to proceed. Should the driver be interrupt driven or polled??? The FIFO buffer will only hold 3 packets before it starts dumping. Also, how configurable does it need to be? I really don't think I want to create a variable/attribute. Maybe the registers like I have them with comments to break down the individual bits in the register? Suggestions and opinions please. |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6609 |
Well commented registers should be enough to let users adapt the code as required. "interrupt driven or polled" will depend on the application also. The main thing is, you have working code to get us started. I have the modules and will try it on micromite V4.6 as soon as time permits. Too much work to do this time of the year and we are running gout of rainy days. Jim VK7JH MMedit |
Since I finally got my sample chips and loaded latest beta I have updated the code to work with nrf24L01+. Currently building an outdoor temperature and humidity sensor that reports back to my linux based weather wall clock. Will post code once I have it somewhat pretty. |
What I am posting here is not pretty but does work. I connected a DHT22 and nRF24L01+ to micromite MK2. On the other end is a pcDuino3 Nano which I wrote python code to control the receiving nRF24. This reads and sends temp and humidity approximately every 10 minutes. 'Micromite remote temperature and humidity sensor
'Uses DHT22 and nRF24L01+ Sub NRF.INIT NRF_CONFIG_RG=0 NRF_ENAA_RG=1 NRF_ENRXADDR_RG=2 NRF_SETUPAW_RG=3 NRF_SETUPRETR_RG=4 NRF_RFCH_RG=5 NRF_RFSETUP_RG=6 NRF_STATUS_RG=7 NRF_OBSERVETX_RG=8 NRF_CD_RG=9 NRF_RXADDRP0_RG=10 NRF_RXADDRP1_RG=11 NRF_RXADDRP2_RG=12 NRF_RXADDRP3_RG=13 NRF_RXADDRP4_RG=14 NRF_RXADDRP5_RG=15 NRF_TXADDR_RG=16 NRF_RXPWP0_RG=17 NRF_RXPWP1_RG=18 NRF_RXPWP2_RG=19 NRF_RXPWP3_RG=20 NRF_RXPWP4_RG=21 NRF_RXPWP5_RG=22 NRF_FIFOSTATUS_RG=23 NRF_CS=5 NRF_CE=6 NRF_IRQ=4 NRF_ADDRESS_WIDTH=5 NRF_PAYLOAD_WIDTH=4 Dim NRF_ADDRESS(NRF_ADDRESS_WIDTH) Dim NRF_RX(NRF_PAYLOAD_WIDTH) Dim NRF_TX(NRF_PAYLOAD_WIDTH) Pin(NRF_CS)=1:SetPin NRF_CS,8 Pin(NRF_CE)=0:SetPin NRF_CE,8 End Sub function NRF.BITTWIDDLE(num,place,value) local junk$,temp$,x$ x$=str$(value) junk$=bin$(num,8) for I=1 to 8 if I=(8-(place-1)) then temp$=temp$+x$ else temp$=temp$+mid$(junk$,I,1) endif next I NRF.BITTWIDDLE=val("&b"+temp$) end function sub NRF.POWERDOWN local junk junk=NRF.READREG(NRF_CONFIG_RG) junk=NRF.BITTWIDDLE(junk,2,0) NRF.WRITEREG(NRF_CONFIG_RG,junk) end sub sub NRF.POWERUP local junk junk=NRF.READREG(NRF_CONFIG_RG) junk=NRF.BITTWIDDLE(junk,2,1) NRF.WRITEREG(NRF_CONFIG_RG,junk) end sub Sub NRF.SETTXADDR local junk SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(NRF_TX_ADDR_RG+32) For I = 1 To NRF_ADDRESS_WIDTH junk=SPI(NRF_ADDRESS(I)) Next I Pin(NRF_CS)=1 SPI close End Sub Sub NRF.SETRXADDR(P) local pipe, junk pipe=&H0A+P SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(pipe+32) For I = 1 To NRF_ADDRESS_WIDTH junk=SPI(NRF_ADDRESS(I)) Next I Pin(NRF_CS)=1 spi close End Sub Function NRF.STATUS() local temp, x$, temp=NRF.READREG(NRF_STATUS_RG) NRF.STATUS=temp x$=Bin$(temp) Do x$="0"+x$ Loop Until Len(x$)=8 NRF_TX_FULL=Val(Right$(x$,1)) NRF_RX_P_NO=Val("&B"+"mid$(x$,5,3)) " NRF_MAX_RT=Val(Mid$(x$,4,1)) NRF_TX_DS=Val(Mid$(x$,3,1)) NRF_RX_DR=Val(Mid$(x$,2,1)) temp=NRF.READREG(NRF_FIFO_STATUS_REG) x$=Bin$(temp) Do x$="0"+x$ Loop Until Len(x$)=8 NRF_TX_FULL=Val(Mid$(x$,3,1)) NRF_TX_EMPTY=Val(Mid$(x$,4,1)) NRF_RX_FULL=Val(Mid$(x$,7,1)) NRF_RX_EMPTY=Val(Mid$(x$,8,1)) End Function Sub NRF.READPAYLOAD Local junk SPI open 100000,0,8 NRF_TXMODE Do Pin(NRF_CS)=0 junk=SPI(&h61) For I=1 To NRF_PAYLOAD_WIDTH NRF_RX(I)=SPI(&h0) Next I Pin(NRF_CS)=1 Loop Until NRF.READREG(23)=17 spi close NRF.RXMODE Pause 200 End Sub Sub NRF.SENDPAYLOAD Local junk 'NRF.RXMODE SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(&hA0) For I= 1 To NRF_PAYLOAD_WIDTH junk=SPI(NRF_TX(I)) Next I Pin(NRF_CS)=1 NRF.RXMODE Pause 10 NRF.TXMODE spi close End Sub Sub NRF.CLEARRXDR NRF.WRITEREG(NRF_STATUS_RG,64) End Sub Function NRF.READREG(reg) Local junk, mybyte SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(reg) mybyte=SPI(&H0) Pin(NRF_CS)=1 spi close NRF.READREG=mybyte End Function Sub NRF.FLUSHRX local junk SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(&hE2) Pin(NRF_CS)=1 spi close End Sub Sub NRF.FLUSHTX local junk SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(&HE1) Pin(NRF_CS)=1 spi close End Sub Sub NRF.WRITEREG(reg, mybyte) local junk SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(reg+32) junk=SPI(mybyte) Pin(NRF_CS)=1 spi close End Sub Sub NRF.RXMODE Pin(NRF_CE)=1 End Sub Sub NRF.TXMODE Pin(NRF_CE)=0 End Sub Function NRF.RX.AVAIL() NRF.RX.AVAIL=0 x= NRF.READREG(NRF_FIFOSTATUS_RG) If x=16 Or x=18 Then NRF.RX.AVAIL=1 End Function Sub TXSETUP SPI open 1000000,0,8 Pin(NRF_CE)=0 NRF.WRITEREG(NRF_ENAA_RG,0) NRF.WRITEREG(NRF_ENRXADDR_RG,1) NRF.WRITEREG(NRF_RFCH_RG,2) NRF.WRITEREG(NRF_RXPWP0_RG,4) NRF.WRITEREG(NRF_RFSETUP_RG,38) '38 is high power low speed setting NRF.WRITEREG(NRF_CONFIG_RG,&B00001010) Pin(NRF_CE)=1 spi close End Sub Sub showRXaddress(x) local temprg, junk, mybyte temprg=&H0A+x SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(NRF_RXADDRP0_RG+x) For i=1 To 5 mybyte=SPI(&H0) Print mybyte; Next i Print "" Pin(NRF_CS)=1 'NRF.READREG=byte1 spi close End Sub Sub showTXaddress local junk, mybyte SPI open 1000000,0,8 Pin(NRF_CS)=0 junk=SPI(NRF_TXADDR_RG) For i=1 To 5 mybyte=SPI(&H0) Print mybyte; Next i Print "" Pin(NRF_CS)=1 'NRF.READREG=byte1 spi close End Sub Sub showregs Local junk,mybyte SPI open 1000000,0,8 For I=0 To 23 Pin(NRF_CS)=0 junk=SPI(I) mybyte=SPI(&h0) Pin(NRF_CS)=1 Print "REG #"+Str$(I)+" = "+Str$(mybyte) Pause 100 Next I spi close End Sub Sub preppayload local temp, humid dht22 2, temp, humid temp=temp*10 humid=humid*10 NRF_TX(1)=temp>>8 NRF_TX(2)=temp-(NRF_TX(1)*256) NRF_TX(3)=humid>>8 NRF_TX(4)=humid-(NRF_TX(3)*256) for I =1 to 4 print NRF_TX(I) next I end sub 'start NRF.INIT NRF.CLEARRXDR NRF.FLUSHRX TXSETUP pause 10000 do NRF.POWERUP preppayload NRF.SENDPAYLOAD NRF.POWERDOWN pause 1000 CPU SLEEP 600 loop |
Looking at last nights data there were some really odd timings with the CPU sleep 600 function. There was a 5+ hour gap and between samples. Anyone have experience with CPU SLEEP function? |
I think I know what happened. Update: It was a bad cap. Noticed timing inconsistency that progressively got worse. Changed cap and timing is within 1 second over 10 minutes. |
Hopefully this is not too far off topic, but I have had good experience with these for rf link between pc and uMite just using serial. I am pretty sure (haven't tried) that using two units (the ones without the usb port plug) between 2 umites would work well also. Great range and very easy to use being serial. What I have used is the pc to umite over these radios and it works very well. From a previous post, Jman has also mentioned these. |
Certainly not off topic. I believe those radios are for 1 to 1 links, yes? This version of nRF software is 1 to 1 also, but it is more like a building block. My plan is to build a mesh network using nrf24's and umite's. This is for a home automation idea I have been thinking about. Each remote node would consist of the nrf24 and 2 mites. One mite would handle just communications and forward information to the 2nd mite. It could be possible to remote program the 2nd mite this way, or to interact directly through the console. There are several mesh micro controllers out there but they are either to expensive to put everywhere, require direct connection to program, or are just to power hungry. |
