Local Time 14:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM.Watchdog
OA47
Posted: 11:39am 29 Oct 2014
Under what circumstances does the MM.watchdog flag get cleared or reset to zero?
Posted: 12:34pm 29 Oct 2014
On a restart (for whatever reason).
OA47
Posted: 02:19pm 29 Oct 2014
Maybe a misunderstanding. I understand that MM.Watchdog is true on a restart due to the watchdog timer but on what conditions is the flag set back to zero?
GM
Posted: 05:28pm 29 Oct 2014
It is set to zero when the uM starts with a normal power up and it is set to true if a watchdog timeout caused the restart. It is not changed until the next power up. Currently a reset (pulling MCLR low) does not change MM.Watchdog, it requires a power recycle (I plan to change this).
Are you seeing something different?
OA47
Posted: 11:32pm 29 Oct 2014
Thanks for the info Geoff all is as you have explained. I am accessing the micromite remotely (via the console port) and would like to reset the MM.watchdog flag but as you have explained I will need to power cycle the micromite.
GM
