Local Time 10:01 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UBW32 PWM
Dinosaur
Posted: 07:57pm 26 Oct 2014
Hi All
I am trying to make the PWM work on the UBW32, with C32 MX795 image in it.
As I can't locate any examples I am hoping someone here can scrutinize my attempts.
All the commands come back with "OK", but no freq is detected on any of the pins.
If I use the pin as a normal output, (driving an opto) it works correctly.
The commands are as per the UBW site, but what I don't know is if you have to set the
pin as an output first, or just don't configure it at all prior to setting it for PWM.
I have tried both to no avail.
Commands in order:
PC,4,1 'set to single channel
PC,2,1,D,1 'use channel 1 as port D pin 1
PC,1,1000 'Divide 80Mhz to get a 80Khz clk
PC,0,2000 'Ticks of 80Khz between pulses, = Frequency
PC,5,1 'Enable the PWM
SP,1,2000 'roughly 50% duty cycle.
Have also tried various orders of these commands, but still no luck.
What am I missing ???
Hervey Bay Qld.
Dinosaur
Posted: 06:13pm 27 Oct 2014
Hi All
It appears that a single channel won't work.
By setting it to 2 channels, it works.
Hervey Bay Qld.
Posted: 06:17pm 27 Oct 2014
Glad to see you were able to work it out.
I have UBW32's but with MM Basic on them.
