Local Time 14:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : function PULSIN on MaxiMite ?
f1fco
Posted: 11:10am 17 Oct 2014
does the function PULSIN exist on MaxiMite ?
what is the actual version of firmwareon Maximite ?
4.5 ?
on MicroMite, it is 4.5D
thank you for answer
Pierre
73s de F1FCO
Posted: 01:11pm 17 Oct 2014
When you power-up the Maximite, it will tell you the firmware version on the start-up screen. Or you can type ? MM.VER at the command prompt, and it will show the version number.
As to PULSIN, no, it does not exist as a command on the Maximite.
Geoff has hinted that porting the new commands from the Micromite, over to the Maximite, is on his to-do pile, but I when that will happen is anyone's guess, as he's a busy fella.
