Local Time 14:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Simple Question
samuelT
Posted: 03:15pm 14 Oct 2014
Hello:
I am new hear and hope you can answer some simple questions.
1) Does the micromite have the library calls to use an SD card?
2) If the MMedit is used does the internal micromite editor need to be used?
3) If i had the Microchip MPLAB-X 'C' compiler then would i get the same compiled
code as comes in a micromite reprogrammed chip?
Thanks for bring me up to speed.
samT
Posted: 05:08pm 14 Oct 2014
Welcome.
1. No the micromite does not have any code for talking to SD cards - Have you looked at the Maximite?
2. If you use MMEdit, there is no need for the inbuilt editor but I do use it for small changes to the code while testing. Reloading a long program for a simple change takes some time so it can be quicker to run the inbuilt editor.
With MMEdit, you can read the code back from the micromite into MMEdit.
3. Compiling the micromite source requires the expensive compiler, not the free one.
samuelT
Posted: 05:08am 15 Oct 2014
Thanks for the info.
samT
