Local Time 13:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uMite and SPI serial flash
Glen0
Posted: 11:24pm 11 Oct 2014
Can anyone tell me how to write to, and read from, SPI serial flash.
I am trying to write data to an 8 pin serial flash ic and then read it back a few hours later.The chip is a SST25VF080B Serial flash memory ic.
Posted: 10:34am 12 Oct 2014
Hi Glen - welcome to BSF. Have you tried 'adapting' the SPI code form the User Manual to work with the Flash IC you refer to?
It should be very easy to do assuming you have the datasheet at hand.
Let us know what you have tried. Most importantly, don't be afraid to try things yourself - it seems to be a 'dying art' (i.e. people ask first rather than trying the 'basics' themselves)
There are plenty of people to help if you get stuck so let us know what you have 'attempted' and we will assist in ensuring your 'success'.
WW
Posted: 02:23pm 12 Oct 2014
Welcome aboard the great ship BackShed.
I don't have any SPI memory chips here of any sort(I always use I2C), but I am interested in your results, so I will be watching this thread. Good luck, and please do post back with your results etc.
Glen0
Posted: 04:08pm 12 Oct 2014
Thanks for the reply.
Must admit I am looking for the easy way out here, I did however have a number of goes at it, including the example in Geoff's manual, but there are just too many unknowns at this stage.
The memory chips data sheet is also a little lacking in mapping detail. So if anyone has any examples of writing to a memory chip using SPI it will be much appreciated.
Being able to record time-stamped data will make this a powerful device.
