Local Time 13:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C READ
palcal
Posted: 05:42pm 06 Oct 2014
I have a program that reads from a BMP085 sensor. I recently upgraded MMBASIC in my Maximite to V4.5 and so had to change the I2C commands.
The code I was using
TEMP: ' Get temperature from BMP085
I2CSEND BMP085_ADDRESS,0,2,&HF4,&H2E
Pause 5
I2CRCV BMP085_ADDRESS,0,2,buffert(0),1,&HF6
temp_uc=(buffert(0)*256)+buffert(1)
Return
PRES: ' Get presure
I2CSEND BMP085_ADDRESS,0,2,&HF4,&HF4
Pause 26
I2CRCV BMP085_ADDRESS,0,3,buffert(0),1,&HF6
pres_uc=Int(((buffert(0)*65536)+(buffert(1)*256)+buffert(2)) /32)
Return
I altered the I2CSEND TO I2C WRITE
and I2CRCV to I2C READ
So now the line reads
I2C READ BMP085_ADDRESS,0,2,buffert(0),1,&HF6
but gives me a syntax error, the same happens with the other I2C READ.
Can anyone help.
Paul.
BobD
Posted: 05:58pm 06 Oct 2014
Paul
The syntax is
I2C READ addr, option, rcvlen, rcvbuf
Maybe it is objecting to the extra two characters on the end ,1,&HF6
Edited by BobD 2014-10-08
paceman
Posted: 07:09pm 06 Oct 2014
Yes, as Bob says Paul, just the four parameters now. I'm using the following line from JMan's DS1307 routines OK for V4.5 on the MicroMite but I think it's the same for the Maximite now.
I2C READ i2caddr,0,8, RTCbuff(0) 'Normal ctrl, 8 bytes, rec'v var
Greg
palcal
Posted: 07:36pm 06 Oct 2014
Thanks, that worked.
I don't understand I2C all that well, will have to study further.
Paul
Posted: 11:33am 07 Oct 2014
Hang in there, Paul. If not for the encouragement of members here such as MOBI(anyone heard from him lately, BTW?), I too would have given up on I2C. Now that I have got the hang of talking to it, I would not think twice about using it, and once you ARE familiar with it, it opens up a whole plethora of extra chips you can interface to the uM.
EDIT: Whatever happened with your VGA-composite problem? Did you get that fixed?Edited by Grogster 2014-10-08
palcal
Posted: 06:53pm 07 Oct 2014
No I put the colour monitor on the back burner, using it in mono at the moment. I bought another monitor will try it with that when I get some time. Gee it's busy when you're retired.
Paul.
palcal
Posted: 11:21pm 08 Oct 2014
Still having problems reading I2C values
I have now tried with a HH10D humidity sensor that worked OK before.
The old code I used was
100 Dim hcal(4)
110 I2CEN 100,400
120 I2CRCV &h51,0,4,hcal(0),1,10
130 I2CDIS
140 If MM.I2C <> 0 Then
150 Print "Error during EEPROM read - error code: ";MM.I2C
160 End
170 EndIf
180 hsens = hcal(0) * 256 + hcal(1):Print "Sensitivity: ";hsens
190 hoffset = hcal(2) * 256 + hcal(3):Print "Offset: ";hoffset
200 SetPin 11,3
210 Do
220 Pause 5000
230 humidity = (hoffset - Pin(11)) * hsens / 4096
240 Print "Humidity: ";humidity;"%"
250 Loop
I have changed to
100 Dim hcal(4)
110 I2C OPEN 100,400
120 I2C READ &h51,0,4,hcal(0)
130 I2C CLOSE
160 End
170 EndIf
200 SetPin 15,3
210 Do
220 Pause 5000
230 humidity = (hoffset - Pin(15)) * hsens / 4096
250 Loop
I know what the calibration values should be, but this code is not giving me those values.
In the original code the read line is
can someone tell me what the 1,10 at the end is, the new code won't let me use it.
I am trying to get 2 values from the eprom, "sensitivity" and "offset"
Paul.
jman
Posted: 11:47pm 08 Oct 2014
Paul.
That was to write 1 byte with the value of 10 before the read
So the new code should look like this
I2C Write &H51, 0, 1, 10
I2C Read &H51, 0, 4, hcal(0)
Jman
palcal
Posted: 11:18am 09 Oct 2014
Thanks Jman I will try that. It makes sense, 10 is the eprom address of the first value I am trying to read.
Paul.
It worked OK. I think I'm starting to get my head around this I2C stuff now.
Thanks all,
Paul.
Just one more thing that is puzzling me, the original code was written by Seco61 back in Jan 2012 in response to a post from me. Nowhere in the datasheet for the HH10D sensor is the I2C address of &h51, so where would this address have come from.
Edit.
The datasheet says the eeprom physical address is fixed at 01 so this is probably a mistake and should read 81.Edited by palcal 2014-10-10
