Forum Index : Microcontroller and PC projects : MicroMite on an Arduino Shield
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
What pins would go to what ? |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048 |
Depends on what you want to do. The sheild pinout can be found here among other places - scroll down a little. You'll need the 3v3 and GND connections for power, but depending on what interface you need back to the Arduino, some of the other pins as well. A4 and A5 are the I2C bus. Smoke makes things work. When the smoke gets out, it stops! |
MicroBlocks![]() Guru Joined: 12/05/2012 Location: ThailandPosts: 2209 |
You could use the CMM pinout as a guide. Most critical will be the RX/TX (serial), SDA/SCL (i2c) and MISO/MOSI/SCK (spi). then the PWM/Digital and analog pins to get as good a match as possible. Microblocks. Build with logic. |
Actually for this project (USB Midi-Synth) all I'll hook up is COM out and Tx Rx . It's interesting though the power permutations. (3.3 vs/and 5.0 Volt) Depending on what's used for power and what's supplied/needed by whatever 'shields' one uses. |
By the time I put in a USB-Serial gizmo there was not enough room for the MicroMite to be comfortable, so I used a PicAxe (also is OK with 5V that the synth needs)
Need the type cable with the circuit on the other end ... (which I don't like for some reason ?) Or a MicroMite with USB built in would be groovy
