Local Time 13:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ASCII-TERMINAL
rentner111
Posted: 11:15pm 26 Sep 2014
QUESTION ASCII terminal
Hi Geoff !
Can you install a command " CURSOR OFF / ON CURSOR " ?
Can you install the extended ASCII character set ?
Important are the German special characters such as Ä - Ö - Ü - ° .
In the ASCII diagram " SINGLE CHIP CONTROLLER " , the polarity when 10yF Elko wrong.
with thanks in advance
Posted: 11:40pm 26 Sep 2014
Hallo. Nicht sicher über die deutschen Sonderzeichen, aber Geoff KÖNNTE können, um sie hinzuzufügen. Wie dem Diagramm ist die Kappe ein SMD 10uF Keramik, und so nicht polarisiert ist. Angenommen, Sie bedeuten, die schematische Darstellung als Teil der Konstrukteurs-Kit erhältlich.
Posted: 11:58pm 26 Sep 2014
  rentner111 said  Can you install a command " CURSOR OFF / ON CURSOR " ?
It could be easily done. The reason why I did not do it in the first place is that the VT100 did not have cursor off/on.
Does anyone know of a standard escape code for this function used in terminal emulators (eg, Tera Term)?
  rentner111 said  Can you install the extended ASCII character set ?
No, this one would be difficult. It would involve a major firmware change and then I would have to do French and all the other character sets.
  rentner111 said  In the ASCII diagram " SINGLE CHIP CONTROLLER " , the polarity when 10yF Elko wrong.
Thanks, I will fix it.
Grogs, are you showing off your talents or did you use Google translate?
Posted: 12:30am 27 Sep 2014
I think DEC used a different (non-ESC) sequence for cursor on/off.
DECTCEM
I understand CSI is 0x9b and cursor off is thus (all hex): 9b 3f 32 35 6c
with cursor on as (hex) 9b 3f 32 35 68
I have no love for the 9b!
JohnEdited by JohnS 2014-09-28
