Local Time 13:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [ASCII Video Terminal] On a 32MX270
Posted: 07:39pm 20 Sep 2014
I have a whole bunch of 32MX270 DIPs and SOICs and would like to use a few as Geoff's ASCII video terminal.
Normally a 250 is used. Can it be substituted for a 270 without changes?
Posted: 07:57pm 20 Sep 2014
I would try it and see with one of the DIPs first.
Worst case - it won't.
But on the other hand, it may well work. What is the difference between the 250 and 270 chips? If it is just more memory in the 270, then I don't see any immediate reason why the larger chip should not work - try it and see!
Posted: 08:44pm 20 Sep 2014
According to the datasheet it is only more memory.
I am wondering about the bootloader, if that is different or not.
I'll give it a go tomorrow with the available hex file.
I am not setup yet to compile it from source.
