Local Time 13:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Test..Can You Hear the MicroMite ?
hitsware
Posted: 03:21pm 18 Sep 2014
http://home.comcast.net/~mnjmiller/temper.mp3
Having some upload sound problems
Posted: 04:20pm 18 Sep 2014
certainly can. it is absolutely neat!
rob :-)
Posted: 04:23pm 18 Sep 2014
I can hear it too.
How are you doing that?
hitsware
Posted: 04:24pm 18 Sep 2014
Thanks and Good-Oh
For some reason I can hear the file on my PC,
but not the uploaded one ....
hitsware
Posted: 04:36pm 18 Sep 2014
All PWM's summed with 15kOhm ... COM1 added with 3.3kOhm
add: Data 2,4,3,4
@ bottom
Edited by hitsware 2014-09-20
Posted: 04:54pm 18 Sep 2014
Very clever use of PWM channels on uM - cool.
hitsware
Posted: 05:08pm 18 Sep 2014
  Grogster said   Very clever use of PWM channels on uM - cool.
2 bad there's not a couple more .........
plasma
Posted: 08:32pm 18 Sep 2014
Haha great
Posted: 09:47pm 18 Sep 2014
  hitsware said  2 bad there's not a couple more .........
Be grateful for small mercies.
I seem to recall that the original uM only had one PWM output, or maybe two. Now it has five.
Oldbitcollector
Posted: 03:59am 19 Sep 2014
Neat!
My Propeller/Micromite mini-computer project.
mindrobots
Posted: 08:31am 19 Sep 2014
This is very cool!
I'll ask a stupid question (because I do it so well and I'm more software than hardware).
When you say, "All PWM's summed with 15kOhm ... COM1 added with 3.3kOhm ", I assume you mean that the PWM's are connected to one point through 15k resistors and then the TX from COM1 is connected to that same point with a 3k3 resistor. That one connection point then becomes "audio out"? Thus summing the signals together into one signal? The resistor are there to protect any of the pins when they go low since there's a good chance that when a pin is low, some other pin is high.
This is very clever and certainly is something to try at home!
Thanks for sharing!!
Rick
hitsware
Posted: 09:33am 19 Sep 2014
Precisely.
The values can be adjusted for mix as the 3k3
(COM1 is the percussion)
Posted: 12:46pm 19 Sep 2014
I wondered about the COM1 thing myself, so thanks for clarifying that. An ingenious use of a serial port! Excellent.
plasma
Posted: 04:28am 26 Sep 2014
I like this kind of muzak so much i buildt this
100% this Weekend!
hitsware
Posted: 04:20pm 28 Sep 2014
  plasma said   I like this kind of muzak so much i buildt this
100% this Weekend!
So how does it sound ???????
plasma
Posted: 07:32pm 30 Sep 2014
Hmm your Sound is much smoother.
Have you use some Filter?
hitsware
Posted: 02:25pm 01 Oct 2014
  plasma said   Hmm your Sound is much smoother.
No filter. Maybe because it's recorded ?
Do you listen to both mine and yours through
the same audio system ?
plasma
Posted: 10:22pm 01 Oct 2014
Ah ,its the media player.
No filter for mikro but "metall" for other audio
plasma
Posted: 02:36am 04 Oct 2014
Hi Hitsware ,
Your song becomes popular!One hit Wonder
Thx for the sound
hitsware
Posted: 07:06am 04 Oct 2014
Thank You !
I hope my Wife will put up with all the Groupies !
AND !!!
Since it is Saturday Night .....
DuinoMite with FluxamaSynth
Edited by hitsware 2014-10-06
