Local Time 13:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : One program per MicroMite ? .....
hitsware
Posted: 09:16am 12 Sep 2014
I must be missing something .
No FILES, or SAVE so just the 'listed'
program in memory ?
Posted: 09:46am 12 Sep 2014
You can change it easily enough via the serial terminal but if you want a computer with FILES etc then it's a Maximite I think.
Oldbitcollector
Posted: 09:57am 12 Sep 2014
Or slap a Propeller with an SD card onto it like we did..
Jeff
My Propeller/Micromite mini-computer project.
hitsware
Posted: 10:58am 12 Sep 2014
My programs are pretty short (and loops)
I guess I'll have 1 long program with several
'reminders to direct to differant 'subroutines'
Posted: 02:10pm 12 Sep 2014
  hitsware said   ....
program in memory ?
You're not missing anything.
The MicroMite is a MICRO-controller, not a computer per-se', whereas the MAXImite is a computer - as it has a keyboard, monitor, and SD card storage.
The MicoMite is a one-program device, as you have guessed. No SAVE or FILES, as there is no SD card - temporarily ignoring the fab MMC by Oldbitcollector.....
It's just like the PICAXE or Arduino in that respect - runs the one program code you put in it, and by DEFAULT, there is no ability to access external storage, unless you add that youself.
hitsware
Posted: 02:22pm 12 Sep 2014
  Grogster said
  hitsware said   ....
program in memory ?
I knew (obviously) it had no external storage.
I figured it would address the internal storage
the same way the MaxiMite addresses the SD ....
But that is fine ... As I said above, 1 long program
with stopping places is OK for my purposes ....
Posted: 02:32pm 12 Sep 2014
Oh - I see - sorry - I misunderstood you there.
Posted: 09:29pm 12 Sep 2014
@oldbitcollector. The above raises a good point; and a feature that was useful on the MaxiMite:
I am not near my MMC at the moment so I can't try this right now - and hence this post.
Is there a way that one running .bas program can call/load/run another .bas program? OR do you need 'manual' intervention to do SD operations?
WW
Oldbitcollector
Posted: 05:01am 01 Oct 2014
I missed this question/thread. I apologize.
I had this feature on my "todo" list until Geoff increased the capability of the BASIC to 54k. I've been a bit "up in the air" on this since as I've never used more than about 17% of the 54k I have.
Is there still reasoning to have this ability with the memory we have now?
Jeff
