Forum Index : Microcontroller and PC projects : VT100 "MODE NOT SUPPORTED"
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
I got a VT100 board together. When plugged into VGA monitor (with or without MicroMite), I get "mode not supported" on the screen. At first I thought it was a message from the board, but now I'm thinking it's from the monitor itself .... Ideas ????? |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6609 |
The monitor doesn't like the scan rate that the VT100 terminal uses. Some monitors only accept a limited range of scan rates. Jim VK7JH MMedit |
Hmmmmmmmmmmmm..... I don't have the jack for composite yet. Might that still work ? |
After adding the solder blob for VGA signal and the LED, the VT100 works (loopback and all)
Still cannot reach the MicroMite though. It's intermittent at best. Best case I get the Basic splash screen, but keyboard doesn't echo. At times keyboard echos, but certain keys give weird results ........ Gettin' closer ............. |
