Forum Index : Microcontroller and PC projects : Altium free package confirmed!
| vasi Guru Joined: 23/03/2007 Location: RomaniaPosts: 1697 |
This is huge! Dave confirms it and says is actually good! The problem is, when that will be? 'cause if we must wait for those new acquisitions first, to develop the commercial high end version, then it will take years and we need it now. Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
MicroBlocks![]() Guru Joined: 12/05/2012 Location: ThailandPosts: 2209 |
I am happy enough with diptrace,as is eagle for many others. Enough for the lower end player. Altium has a high(steep) learning curve, completely unnecessary for 99.99% of those users. They already lost the battle before they (will) start. Microblocks. Build with logic. |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2984 |
Interesting Vasi, I wonder if it will be able to read in my PCBs I designed with Protel 99se?> Keep us informed if you hear anything.. On a side note.. I saw this at the bottom of the page TRS-80 Tear down Brought tears to my eyes.. Probably from the memory of all the cigarette smoke Don used to blow in my eyes whilst we were staring at these beasts.. I cut my teecth on TRS-80s Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10108 |
Well, quite. Agreed.Smoke makes things work. When the smoke gets out, it stops! |
It will be a little different that Altium Designer. New interface, new shortcuts. It will be an Eagle/KiCAD killer - this is the goal. But they "lost the battle" elsewhere: - No local savings - all are cloud based. - All your final projects are public. The temporary work (only one at a time) is private until you finalize it. - Only on final projects you are able to generate gerbers, which can be downloaded. - You can have private projects if you buy this right (the more projects, the more expensive). So, is a no go for me. Not interested even an millis. I will continue to use Eagle, DipTrace, KiCAD, gEDA. Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
Another huge handicap is that it will be windows only. Eagle, Kicad and gEDA are already cross platform applications as DipTrace is. No excuse for the free EDA from Altium. Why? Here are some reasons: - it is written from scratch so, they can chose even the language. Personally, I guess that this one will be the base for a totally rewritten Altium Designer; - DipTrace is a Delphi application and Embarcadero Delphi can create native applications for Windows, OS X, iOS and Android (they will offer some viewers and maybe some light project editors for touch screen devices in the future). Linux is in the work so we soon will have DipTrace for Linux as well. Altium Designer was a Delphi application but somewhere in time, someone decided to rewrite a lot (not all) of code in C++ and C#. Now they are trapped in the Windows world. A big fail. (Parenthesis) Someone will say that they can't justify the extra development effort required to support the other two major operating systems but that is not true because there is no extra effort. You write your application only once and the compiler will generate code for all the targeted operating systems. And now it will be a good time (I guess is the only chance) for them to start working on a cross platform application. (/Parenthesis) - they have a huge capital to protect. In time, they will be equaled by DipTrace and KiCAD regarding the options and features. BTW, KiCAD already offers the "push&shove" feature in the development branch. Which the free EDA from Altium does not have!!! Look here. Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
| graynomad Senior Member Joined: 21/07/2010 Location: AustraliaPosts: 122 |
I'm still interested in it but the cloud-only storage is probably a deal breaker. This feature alone must have accounted for 90% of the negative comments on EEblog. Rob Gray, AKA the Graynomad, www.robgray.com |
