Local Time 07:55 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Diodes with electro sounders?
Posted: 03:14pm 04 Sep 2014
I have some nice cute little electro sounders:
SOUNDER
These do not have built-in drivers, so I am driving them with PWM from the uM, and they work fine.
As they are a 3v device, I am not using any buffer transistor, and am driving them direct from the uM pin, as the current consumption is supposed to be 14mA @ 2kHz or so, so feel that is still within the limits of the uM pin.
The sounder is not driven continuously, only for alerting purposes.
I currently have a reverse-blocking diode across the sounder to ground, a-la the same idea as a diode across a relay coil, but am wondering if this is needed with only a 14mA current or so?
At this stage, I have left it in place, but just wondering what others think.....
EDIT: Just double-checked the specs for the uM I/O pins, and I am probably pushing things a bit 15mA is the maximum, and 15mA is what this device uses at 3v. Perhaps it would be prudent to put a transistor driver in afterall?Edited by Grogster 2014-09-06
hitsware
Posted: 03:40pm 04 Sep 2014
Cathode towards the uM pin right ? Sounder from pin to ground ?
I'd take it out, and put a capacitor in series.
(value depending on how low you want to go)
That will relieve the pin of delivering DC if it happens to go high.
The pins can evedently drive DC into 82 Ohms, but no use making
heat for nothing......
Posted: 06:16pm 04 Sep 2014
K of diode to uM pin, and sounder to GND - correct.
OK, I experimented with various value caps, and 100uF works well to provide about the same volume from the sounder as a direct connection.
Will the cap isolate the pin enough?
palcal
Posted: 08:12pm 04 Sep 2014
The diode across a relay is to suppress the spike created as the magnetic field around the coil collapses creating a back EMF. I don't think the same thing would happen with a transducer.
Paul.
hitsware
Posted: 09:20pm 04 Sep 2014
Since the resistance of the coil is 42 Ohm, worst case
would be an instantaneous spike of ~ 3/42 Amp. An added
series 39 Ohm resistor would be super safe at the expense
of some efficiency.
Posted: 12:03am 05 Sep 2014
@ Paul & hitsware - Thanks for the feedback, guys. I will stick with the transducer via a 100uF cap in series, no back-EMF diode.
Thank you both for your input.
atmega8
Posted: 03:55am 05 Sep 2014
Ok,
what about Dildos with electro Sounders??
Any experience in this?
Posted: 03:55pm 05 Sep 2014
Not my area - how about you?
hitsware
Posted: 05:54pm 07 Sep 2014
How low can you hear your sounder ?
' up down arrows for frequency
' left right arrows for dutycycle
f=110: p=50: GoTo display
setf:
If KeyDown=0 Then GoTo setf
If KeyDown=128 Then f=1.01*f
If KeyDown=129 Then f=f/1.01
If KeyDown=130 Then p=1.01*p
If KeyDown=131 Then p=p/1.01
If p>100 Then p=100
If p<0 Then p=0
PWM f,p
Pause 100
display:
Cls
Print "frequency="f;" dutycycle=";p
GoTo setf
Posted: 09:06pm 07 Sep 2014
KeyDown not supported in uM, only on full size MaxiMite.(uM is what I have setup on the bench at the moment)
I will see if I can hook one up later.
hitsware
Posted: 02:34pm 08 Sep 2014
uM or with using PC for terminal ?
Posted: 03:03pm 08 Sep 2014
KEYDOWN is a command supported in the MaxiMite version of MMBASIC, but not in the MicroMite version, according to the manuals.
It's no big deal - I was going to hook up a mock MM using a UBW32 module, so that I could test it with a VGA-TV converter for another member here, so I can use it for that.
Testing a beeper this way is a little subjective though, as different people have different hearing abilities or lack thereof.
Is there some special reason you need to test this on these beepers?
I could send you one if you wanted to play with one - I have 20.
hitsware
Posted: 03:31pm 08 Sep 2014
Nah .... Just for fun....
Back to INKEY$ then
I like KEYDOWN for ease
of using the arrow keys
There is a way to use arrow
keys with INKEY$, but I've
forgotten. Something about
the second byte of the ASC#?
