Local Time 15:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Neopixels!
aargee
Posted: 02:12am 03 Sep 2014
Has anyone done any Neopixel work with the 'mite (any flavour of mite)?
Adafruit has libraries for the Arduino, could bit bang it with a Micromite but it may be too slow.
plasma
Posted: 02:18am 03 Sep 2014
http://youtube.com/watch?v=IGinUJQFfy0
aargee
Posted: 02:35am 03 Sep 2014
I assume that's your work, Plasma? Very nice.
Did you bit bang the string in Basic?
plasma
Posted: 02:52am 03 Sep 2014
Yup its me .
The bitbanging are done with my own intern command
Called ledshift , at this time it uses string for the colorbytes
Which will shifted and rotatet with mmbasic standard commands.
Maybe geoff will implement my routine some day.
I have no compiler for the micromite , unfortunately.
aargee
Posted: 01:36pm 03 Sep 2014
So did you modify an early version of the Maximite software to make the command or did it some other way?
plasma
Posted: 07:08pm 03 Sep 2014
I extendet the commandset ,right.
MMbasic itself runs to slow for bitbanging.
Posted: 07:33am 08 Feb 2015
  Quote  I have no compiler for the micromite , unfortunately
If you download MPLabX and the XC32 compiler from Microchip that is all you need to start writing Cfunctions
If you can add a command to the Maximite then you shouldn't have any problem writing a Cfunction for the Micromite
Copy any of my C code in various posts and get CFuncGen from
G8JCF which includes a full manual.
I'm happy to answer any queries and it would be great to have another Cfunction author up and running
Zonker
Posted: 12:14pm 08 Feb 2015
Thanks Peter..!
I am just getting the needed software downloaded... I am reading through the Excellent Manual that has been written on how to do this... (nice)
Thanks for showing us where to get started..!
Zonker
Posted: 01:28pm 08 Feb 2015
Ok...
I hit my first snag...
I am following along with the manual about doing the first tutorial about reversing a MMbasic string... Got through the MPLab and compiler setup and created the "ELF" file... (which goes ok) but when I run the CFuncGen program and load the "ELF" file, nothing shows up it the working panes to look at...
I went through the MPLab setups for the project again to make sure every thing is ok... Not sure what I'm doing wrong here...
The only thing I setup differently is the working directory...
does it have to be C:\CFunctions..?
I set mine to the micromite area where I have the rest of my programs stored. I created a separate CFunctions folder to hold the MPLab output files...
Thanks for any help..!
Posted: 12:08am 09 Feb 2015
Zonker
This is a standard problem which I struggled with too.
When you install XC32 you need to tick the box that says something like "include xc32 in path" otherwise you get this problem
Re-install xc32 making sure you tick the path box
Zonker
Posted: 12:54am 09 Feb 2015
Cheers Pete..!
I do remember seeing the PAHT box... I was wondering if I should have checked it...
EDIT: Have reinstalled the compiler and now am getting the CFunction to show up in the CFunction Generator App... Will get back on the string tutorial... Edited by Zonker 2015-02-11
