Local Time 13:19 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Mysteries of VGA ......
hitsware
Posted: 04:18pm 01 Sep 2014
Recently my ColorMax has lost 1 primary color.
The whites are sorta violet.
No big deal for my purpose.
Today I bought a KVM switch so as to go back and forth between
the the ColorMax and my Linux PC.
NOW !
The PC also exhibits precisely the same color aberation !
What's with that ?
Posted: 04:49pm 01 Sep 2014
Sounds like its dropped a colour signal line.
On you PC, open paint and see if you can draw a blue, red and green line. If one of them is missing, or very off colour, then you've dropped a colour.
Could be a bent pin in the VGA connector. Common.
Or, if its a CRT monitor, dry solder joints in the colour path. Usually its on the neck board, back of the CRT. There are 3 power transistors that control the colour guns, and these run warm and get dry joints. Also check around the colour driver IC, its a big IC and can get dry joints.
Make sure its been turned off for a while, the neck board has some dangerous voltages present when running.
Glenn.
Posted: 04:50pm 01 Sep 2014
Hang on, just re-read your post, re the KVM switch. So maybe a dirty connector / switch as well.
OA47
Posted: 05:19pm 01 Sep 2014
Reading your post hitsware, as gizmo mentioned, I might suggest that one of the pins in your VGA connector may be pushed back into it housing or bent.
Best of luck
GM
hitsware
Posted: 03:28am 02 Sep 2014
Yep....Thanks
Just a bad monitor cable. It happened that when it was plugged directly into the PC it was bent right to make it OK. Otherwise bunk.
