Local Time 13:19 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : checking output pin status
DaveC166
Posted: 06:07pm 31 Aug 2014
Hullo
My Umite HRV controller is making progress. however I am having trouble checking the status of digital output pins 9 and 10.
The statement IF PIN(9)=1 or Pin(10)=1 Then pulse 24,50 causes the error not an input pin and the Umite resets.
Is there correct syntax for using the state of an output pin in an IF statement
jman
Posted: 07:09pm 31 Aug 2014
Hi
The reason you get the error is because your pins are set as outputs and to use the
If PIN(x)=x the pins MUST be set as inputs.
If you are setting the outputs can you not keep track of the state that you set the pin to.
If you post your code here I am sure the smart people here will have a solution
Jman
Posted: 07:36pm 31 Aug 2014
As jman says - pin needs to be told it is an input first. This is NORMALLY done at the top of the code, before the main loop or loops.
SETPIN 9,DIN:SETPIN 10,DIN will set pins 9 and 10 to be inputs.
Note that you also have to declare the pin you are using for pulse, as an output first, for exactly the same reasons as the inputs.
SETPIN 24,DOUT
If you make those two changes to your code, the rest of your code should work.
DaveC166
Posted: 08:41pm 31 Aug 2014
Thanks for the replies. Pins 9,10,24 are set to DOUT. Pin 24 pulses a led, Pins 9 and 10 are connected to MOC3021 triac optocouplers . I was trying to port as much code from a PICAXE 28x2 as I could. PICaxe basic allows the state of an output to be tested in IF statements.I guess I will have to set up variables to track the state of output pins in MM Basic.
Posted: 09:00pm 31 Aug 2014
You only need the first of my lines in bold then.
I don't normally need to change the pin state in my applications, but that is just me - I tend to assign pins a certain task from the outset, and not double-up on pins by making one pin an input in one loop, and an output somewhere else kind of thing.
Not to say you can't/shouldn't do that - it's up to you, but as you have discovered, you will need to track the pin's state.
You could do this as simply as with a flag:
flag_pin24=1, then just check that flag if you need to change it from output to input kind of thing at the time. Logic 1 could mean output or input, depending on how you assign the flag, but the opposite would be the other.(if 1 was output, then 0 would be input)
Posted: 09:04pm 31 Aug 2014
Hi Dave,
Another possible solution (if you have two spare I/Os) is to keep pins 9 & 10 as outputs and then connect each of them to the two 'spare' pins which are both set as inputs. Then you can use the IF statement on the Input pins then everything will work ok.
This is not necessary the 'best' solution - but it is a solution that works quickly (but only if you have two spare pins) that you may not have thought about.
Let us know how you resolve your IF statement . . .
WW
DaveC166
Posted: 09:27pm 31 Aug 2014
I have altered my code so that if I set a DOUT pin to 1, I set a flag variable to 1. This gets around not being able to use the state of a DOUT pin in a IF statement.
ajkw
Posted: 10:12pm 31 Aug 2014
If you had a suitable pull up resistor on the pin then this may be a solution.
x = {valid digital pin number}
setpin x,oout
pin(x) = 1
print pin(x)
pin(x) = 0
print pin(x)
paceman
Posted: 04:43am 01 Sep 2014
  DaveC166 said   Pin 24 pulses a led, Pins 9 and 10 are connected to MOC3021 triac optocouplers .
Dave,
watch the 15mA (max) trigger current requirement for the 3021. The MicroMite 150 chip spec quotes a source/sink max of 10mA. It might be OK but you could also use MOC3022's (max 10mA trigger) or MOC 3023's (max 5mA trigger).
Greg
DaveC166
Posted: 09:45am 01 Sep 2014
thanks
Ive got 220 ohm resistors between the Umite output and the MOC3021 input.
