Local Time 13:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C LCD backpack Library
viscomjim
Posted: 12:55pm 25 Aug 2014
I don't know if this has been covered yet... I loaded the I2C LCD library from Peter G8JCF and connected a typical 1602 with the "typical" I2C back pack. Ran the code and viola, everything worked out of the box.
Tried another one with a different Chinese backpack and nothing worked. Did a little homework and found that it needs to be init'ed like this...
LCD_INIT &H20, 0, 6, 4, 7
with backlight on = 0 and off = 1 - worked great!!!
The first one worked fine from the library init as...
LCD_INIT &H27, 1, 0, 2, 3
with backlight on = 1 and off = 0
Both modules from ebay.
Hope this helps someone who got the same one I did. Edited by viscomjim 2014-08-26
G8JCF
Posted: 12:01am 26 Aug 2014
Hi Jim
I have update the LCDI2C Lib to allow users to specify Inverting/Non-Inverting backlight control when calling LCDI2C_Init. The updated LIB is available for download from LCDI2CLibV6.zip
Since you've got an inverting backlight control LCD, could you please test and confirm ?
NB Once you have specified Inverting or Non-Inverting in LCDI2C_Init, thereafter calling LCDI2C_BackLight(1) will always turn ON the backlight, and LCDI2C_BackLight(0) will always turn OFF the backlight.
73
Peter
The only Konstant is Change
viscomjim
Posted: 12:01pm 26 Aug 2014
Hi Peter,
Works perfect!!! Thanks.
G8JCF
Posted: 12:42pm 26 Aug 2014
Hi Jim
Great News, thanks for the report
73
Peter
