Local Time 13:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : On timer ...
plasma
Posted: 09:51pm 21 Aug 2014
What do you think of a new command
Such like " on timer(x) gosub xyz"
I know an interupt enabled pin and a
555 will do to same but a command
can change the timer with software.
Posted: 09:57pm 21 Aug 2014
You could do the same thing with an interrupt...
Example: SETTICK 1000,XYZ
You can have up to four different tick timers running like this.
The above example assumes timer #1, as no number is specified, however, if you needed to setup multipule ones, you could use SETTICK 1000,XYZ,2 which would set tick timer #2 to loop to sub XYZ every second.
plasma
Posted: 10:04pm 21 Aug 2014
Ah ok , i forget this ..
Thx a lot
Posted: 10:21pm 21 Aug 2014
SETTICK is a great command.
I use it in my system in a couple of ways.
One is every 250ms to update the on-screen clock display, a 2nd timer to check if there is any data in the serial buffer that needs attention, and a 3rd to check every second if the system needs to crank up the screensaver cos no-one has pressed a key.
Just remember - use IRETURN in your sub, as this is an interrupt, tripped by the timer(s), so plain END SUB won't work, or will give unpredictable results.
plasma
Posted: 11:42pm 21 Aug 2014
Will a to long working interrupt routine
Overriding the next calls. ?
Cant test yet so i ask
Pseudocode
Settick 100,xyz
Sub Xyz :
Pause 250
Ireturn
End dub
Posted: 11:47pm 21 Aug 2014
Just a point of clarification.
IRETURN is used to return from the interrupt when the interrupt called a label. A subroutine can also be specified for the interrupt target and in that case return is via EXIT SUB or END SUB (not IRETURN).
plasma
Posted: 11:53pm 21 Aug 2014
Thx Geoff
G8JCF
Posted: 12:02pm 22 Aug 2014
@plasma
ISRs/Setticks should be kept as quick as possible, Only do the bare minimum in the ISR. This approach tends to lead to a more responsive system.
The technique I use is to have Main Do ..forever.. Loop which checks for Global flags which are set ON by the ISRs/Setticks when an Interrupt occurs, eg
'Here on Settick 1
'Settick 1 ISR
UpdateLCD:
'Signal that if the LCD needs updating now's the time to do it
DispTick=1
'Is Backlight already OFF
IF BacklightTimer>0 THEN
'No so count down
BacklightTimer=BacklightTimer-1
'Is it time to turn OFF the backlight ?
IF BacklightTimer<1 THEN
'Signal request that Backlight should be turned OFF
BacklightOnOff=&H01
ENDIF
ENDIF
IRETURN
Then in the Main Do ...Forever .... Loop, when it notices that one of these global flags is set ON, code is actioned, and that code can be long stuff. When that code has finished, the Main loop resets the global flag. eg
'Has there been a Display Tick AND a Request to Display ?
IF (DispTick AND DispRqst) THEN
CPU 48
DispFreq
'Reset the Display Request & Display Tick flags
DispRqst=0
DispTick=0
'Slowdown the CPU to save power
CPU 5
ENDIF
'Has there been a request to Turn ON | OFF the LCD backlight ?
IF (BacklightOnOff<>0) THEN
CPU 48
IF BacklightOnOff=&H01 THEN
LCDI2C_BackLight(0)
ELSE
LCDI2C_Backlight(1)
ENDIF
BacklightOnOff=&H0
CPU 5
ENDIF
Hope this helps
Peter
The only Konstant is Change
Posted: 04:31pm 22 Aug 2014
  Geoffg said   Just a point of clarification.
I had that wrong then - sorry Plasma!
