Local Time 13:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can too large of capacitor ......
hitsware
Posted: 03:40am 21 Aug 2014
..... hurt anything on micromite ?
Found a good deal ....
Posted: 04:52am 21 Aug 2014
Is that the capacitor you want to put on pin 19 and 20?
Because there are better and cheaper alternatives available like a 10uF/16V X5R Multi Layer Ceramic Capacitor that can be had for around 0.30US$.
If it is used as an capacitor on the power rails you have to consider that when used on an USB connection the recommended maximum is 10uF total capacitance on the USB power rail to prevent large inrush currents.
Edited by TZAdvantage 2014-08-22
hitsware
Posted: 05:21am 21 Aug 2014
Thanks.
Yes.
Seems the multilayer are SMD types.
I want to simply plug into breadboard.
This for power
"Inrush" on the chip itself is my concern
(Now that you mention the term )Edited by hitsware 2014-08-22
Posted: 06:14am 21 Aug 2014
The SMD types are not that small (1210).
For breadboard use i just solder them on a 2 pin header.
Posted: 06:33am 21 Aug 2014
  hitsware said  "Inrush" on the chip itself is my concern
That capacitor is OK and will not hurt the Micromite.
hitsware
Posted: 09:10am 21 Aug 2014
Thank You and Good-Oh ! .... 'cause I already ordered a few ........
