Local Time 13:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick handshaking question - CTS & RTS...
Posted: 09:12pm 11 Aug 2014
Hi folks.
Normally, I don't use the handshaking lines, and just use TXD and RXD in my 232 corrector designs, but this time, I need the handshaking lines, to make use of the automatic handshaking feature of the MaxiMite COM1 port.
Are the CTS and RTS lines straight through, or do they cross over like the TXD and RXD does?
IE, is this correct:
TXD-RXD
RXD-TXD
CTS-CTS
RTS-RTS
...or is THIS correct:
TXD-RXD
RXD-TXD
CTS-RTS
RTS-CTS
I have a feeling that the first one is the correct one, as although the data is bi-directional, the handshaking lines are just high/low lines, rather then having a specific "Direction".
Do I have this right or wrong?
Thanks.
atmega8
Posted: 09:37pm 11 Aug 2014
RTS WAITS FOR THE ANSWER OF CTS...AND SO ON.
SO RTS HAS TO BE CONNECTED TO THE CTS OF THE COMMUNICATION PATTNER.
Posted: 10:37pm 11 Aug 2014
Thanks.
atmega8
Posted: 12:25am 12 Aug 2014
Furthermore is RTS an Output and CTS an Input ( from the view of a PC).
