Local Time 12:53 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MICROMITE DATE CALCULATION
OA47
Posted: 12:58pm 30 Jul 2014
I will put this one to the TBS thinktank. I am trying to keep a track of date using the VAR SAVE and VAR RESTORE to cover the case when the solar power supply may dip too low and cause a reset. At midnight I test the date and if the date is newer than that saved it should be updated. The problem is the code I am using is taking too much memory and crashing regularly. Can anyone think of a more efficient way to do this? This is the error that appears:
[73] DATREV$=Right$(Date$,2)+Mid$(Date$,4,2)+Left$(Date$,2)
Error: Not enough memory
This is the snippet of code that's checks:
If Time$="00:00:10" Then 'UPDATE LAST KNOWN DATE
ALARM1=0 'RESET ERROR COUNTER
DATNVM$=Mid$(INFO$,19,2)+Mid$(INFO$,14,2)+Mid$(INFO$,11,2)
If Val(DATREV$)>Val(DATNVM$) Then
INFO$=Left$(INFO$,10)+Date$
VAR SAVE INFO$
Print "NEW NVM INFO$ SAVED ";INFO$;
EndIf
Print " ERROR COUNTER RESET TO ";ALARM1
Pause 600
EndIf
GM
BobD
Posted: 01:59pm 30 Jul 2014
You could try using all MID$
If Date$ is dd/mm/yyyy then
[code]
DATREV$=Mid$(Date$,9,2)+Mid$(Date$,4,2)+Mid$(Date$,1,2)
[/code]
OA47
Posted: 01:06pm 01 Aug 2014
Bob, I wasn't sure if changing to Mid$ would make a lot of difference but I am not aware of how both functions operate within MMBasic. I did give it a whirl.....
[60] DATREV$=Mid$(Date$,7,2)+Mid$(Date$,4,2)+Mid$(Date$,2,2)
Still same result
BTW here are the memory stats just prior to the Error
Flash:
16K (82% of 20K) Program (625 lines)
28b ( 1% of 1536b) 1 Saved Variables
RAM:
19K (85%) 62 Variables
1K ( 2%) General
2K (13%) Free
BobD
Posted: 02:16pm 01 Aug 2014
Graeme, I don't know the internals of MMBasic but here is a guess. Your problem is the last status line of RAM. 2K free. If I recall correctly, strings are 256 bytes each and in that line of code you may be allocating 4 of them even if only temporary. Try splitting that line up into 2 or 3 concatenations. Use your original code if you want.
[code]
DATREV$=DATREV$+Mid$(Date$,2,2)
[/code]
or
[code]
DATREV$=DATREV$+Mid$(Date$,4,2)
DATREV$=DATREV$+Left$(Date$,2)
[/code]Edited by BobD 2014-08-03
Posted: 02:33pm 01 Aug 2014
Do you need to do the test at all?
Why not simply update Info$ whenever the time is right.
It should have changed but if not, no harm done.
VAR SAVE INFO$
Pause 600
EndIf
It reminds me of a program I wrote to fix a year 2000 bug in some customers PCs.
They were too tight to upgrade the hardware.
JimEdited by TassyJim 2014-08-03
Posted: 04:04pm 01 Aug 2014
too many strings in your code - with the advent of the micromite it might be a good time to ask geoff to revisit the notion of being able to set the length of regular strings (as opposed to only arrays of strings). either globally, or via static declarations.
but as things stand, you can either use far fewer strings in your code, and recycle them wherever possible, or use arrays of strings, where the length of the strings in an array can be fixed at something much less than 255 characters each.
rob :-)
OA47
Posted: 09:57pm 01 Aug 2014
  Quote  Do you need to do the test at all?
I have been thinking since your post Jim, and haven't convinced myself why I should keep the test for a newer date. Possibly the only reason would be if corruption of the instruction to update the clock throws things out of wack. I like to keep things as simple as possible and will go with your thought of just save the new date anyway and see how it goes.
Thanks for your input
GM
