Local Time 06:55 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Poll GPS Module
edu001
Posted: 01:31am 28 Jul 2014
Hi
I am getting close to the end of building a GPS based tracker
I Have sent a command to the uBlox GPS module on com2 using this which I think should have worked
UBX$ = "BB56206242400FFFF060300000000102700000500FA00FA0064002C0100 0000000000000000000000000016DC"
5005 FOR A=1 TO 44
5010 'DO
5020 Hax$ = MID$(UBX$, A*2, 2)
5040 PRINT #1, ; Hax$
5050 PRINT ; Hax$
5060 '
5070 'LOOP
5080 NEXT A
5090 PRINT ; "DONE UBX"
6000 RETURN
Now I need to poll com2 for the confirmation
Any Ideas
Posted: 03:11am 28 Jul 2014
At first glance, your mid$ statement will send '56' on its first iteration. If you want 'BB' to be sent first then you need to stick in two dummy characters (these will be skipped) OR change either your formula and/or your for/next counter.
Next point, are you wishing to send these as hex bytes? Your routine currently will send the hex value of each character i.e. two bytes per 'pair' of characters. So '56' will be sent as two bytes &h35 and &h36. Is this what the uBlosGPS requires?
WW
Posted: 03:17am 28 Jul 2014
You may have mistyped the 'string' but I seem to be counting 44.5 pairs of characters! Could be my eyes but have got same results five counting attempts in a row.
edu001
Posted: 03:23am 28 Jul 2014
This is the output I get the first B is a Dummy Character
I have just printed it to confirm what is being sent
> RUN
B5
62
06
24
24
00
FF
FF
06
03
00
00
00
00
10
27
00
00
05
00
FA
00
FA
00
64
00
2C
01
00
00
00
00
00
00
00
00
00
00
00
00
00
00
16
DC
DONE UBX
$$$$EDUHABP,1,13:17:21,5232.32403,-152.685,08,146.0,25.25
$$$$EDUHABP,2,13:17:22,5232.32385,-152.685,08,145.8,25.25
$$$$EDUHABP,3,13:17:27,5232.32358,-152.685,07,145.4,25.25
$$$$EDUHABP,4,13:17:40,5232.32365,-152.685,07,145.4,25.25
