Local Time 10:27 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM update to 4.5, now output error
Posted: 04:47pm 24 Jul 2014
Hi folks.
I downloaded an updated a CMM to version 4.5, now a program that was running fine in 4.4 throws this error when I try to run it:
[24] SetPin D11,9:SetPin D12,2:SetPin D13,2:Port(D2,8)=1
Error: Invalid output pin
I will check the update text file, but I don't immediately see why MMBASIC is upset when this line of code was fine in 4.4.......
EDIT: Tried changing the line so that the output pin is OOUT instead of 9, but got the same error.
Downgraded the firmware to version 4.4, and the error is gone, and the code runs as expected.
Curious....Edited by Grogster 2014-07-26
BobD
Posted: 04:53pm 24 Jul 2014
Hi Grogs
separate your code and find out which pin it is. You can then submit a bug report.
BobEdited by BobD 2014-07-26
Posted: 04:54pm 24 Jul 2014
Error gone when I downgrade to 4.4 - see my edit above....
Posted: 05:28pm 24 Jul 2014
It might be related t this problem:
http://www.thebackshed.com/forum/forum_posts.asp?TID=6710&PN =3&get=last#70366
It is the PORT command having problems there but the error looks the same.
Posted: 12:19am 25 Jul 2014
This does seem like a bug.
I will add it to the todo list for the next version.
Tendor
Posted: 11:47pm 13 Dec 2017
I know that things have moved on quite a bit, and this is revisiting very old ground...
Is there any plan (Geoff?) to issue a V4.5.X of the Maximite firmware that has this PORT bug fixed?
I use V4.4B as I use the PORT command to drive stepper motors (monochrome MM). It does not work with V4.5. But I then miss the nice enhancements that V4.5 contains.
I've searched the forum but cannot find any reference following this post (and the one linked below). If anyone has any updated info, I'd appreciate the help.
https://www.thebackshed.com/forum/forum_posts.asp?TID=6875&KW=port+bug
Thanks.
Rod.
MauroXavier
Posted: 12:09pm 20 Feb 2018
I'm waiting for this fix for a while too.
I need to use port command to control a SN76489 PSG, but in 4.4b firmware I loose peek and poke commands.
Posted: 12:53pm 20 Feb 2018
This one must have got lost between the cracks. I have added it to the current bug list but I need to setup the test environment so it may be a little while .
MauroXavier
Posted: 01:59pm 20 Feb 2018
Thank vou very much, Geoffg.
With this fix I can optimize the sound library.
I'm finishing the media editor to CMM and the port, peek and poke commands are very important. With this media editor anyone will can read and create sprites, fonts, screens, maps and musics entirely in CMM hardware, without a PC, like the good old times.
Posted: 05:36am 03 Mar 2018
Could you please try this version (V4.5B): 2018-03-03_152807_ColourMM_MMBasic_V4.5b.zip
I'm sorry to use you as an unpaid tester but after all this time it was amazingly difficult setting up the old compiler chain, etc and then both of my Colour Maximites chose this time to develop some sort of mysterious fault which cut short my testing.
I am reasonably sure that I have nailed the bug but I need a third person to verify this.
Tendor
Posted: 01:21pm 10 Mar 2018
Thanks for addressing this Geoff. I did not notice your post until a couple of days ago and hence the delayed reply.
I have loaded version V4.5B onto my Monochrome MM. At the end of the usual process, with the green 'power' LED flashing slowly, power removed and re-applied,
it appears to not boot. No green LED nor any output to screen.
I tried several cycles of loading V4.5B and then V4.4B.
V4.4B loads and boots fine.
V4.5B - as above, not booting.
Thanks,
Rod.
Posted: 02:31pm 10 Mar 2018
  Tendor said   I have loaded version V4.5B onto my Monochrome MM. At the end of the usual process, with the green 'power' LED flashing slowly, power removed and re-applied,
Is the Colour version not different from the Monochrome version?
Tendor
Posted: 03:10pm 10 Mar 2018
Thanks WW. Yes, of course. I had forgotten that they were different firmware hex files.
Posted: 03:23pm 10 Mar 2018
My fault, I thought that only the CMM version was needed. I will generate a monochrome Maximite version and post it tomorrow.
Tendor
Posted: 03:26pm 10 Mar 2018
That would be great thanks Geoff.
Regards, Rod.
Posted: 03:32pm 10 Mar 2018
@Geoff
I just tried the above CMM 'test' version (on your original CMM) and it still gives the same error.
Have re-flashed (and re-downloaded) three times now just to be sure I have the intended test firmware you posted.
Posted: 03:35pm 10 Mar 2018
Can the PORT command use a 'D2' reference (as in Grogster's example)?
Posted: 03:42pm 10 Mar 2018
Whatever I try, even with:
PORT(x,1)=1
I get an Error : Invalid output pin
Posted: 02:21am 11 Mar 2018
OK, please try this: 2018-03-11_121510_Maximite_V4.5C.zip
This contains version V4.5C for both the colour and monochrome Maximites. I have tested it and the PORT command/function works (for me). Note that this is an update so you do need to load it via the bootloader (not a PICkit3).
Anyone who does test it, could you please report back on how it worked for you. Thanks.
Posted: 03:44am 11 Mar 2018
This program runs without error on a mono Maximite:
  Quote   ' mono maximite tester
SETPIN 15,DOUT
SETPIN 16,DOUT
SETPIN 17,DOUT
SETPIN 18,DOUT
FOR n = 1 TO 16
PORT(15,4)=n
PAUSE 20
PRINT n
NEXT n
It's one that failed earlier
